Cypress技术william hill官网
张超
7年用户 1301经验值
怎么将Fx连接到外部存储器
采用EVL FX2 cy3681board Cypress使用KEIL版本3(完整版…)我不能计划我的计划在8k显示过流错误如果代码+数据太长& gt;8K芯片连接到外部memorycy7c1019cv33-12vci不知道如何定义在keil 3版本和设置W的FX2使用内存和代码whytheoff芯片记忆定义为XDATA RAM EPROM和?
可以帮助我定义这些设置。
感谢
以上来自于百度翻译
     以下为原文
  using the evl fx2 CY3681 board from cypress using the keil ver 3 (full version ...)
i can not program my program over 8k it shows over flow error if the code + data is too long >8k
the chip is connected to the external memory CY7C1019CV33-12VC i don't know how to define the setting in keil ver 3 how the fx2 will use that memory, and why the off-chip memory for the code is define as eprom and xdata as ram?
    could help me define those setting ..
    Thank
回帖(1)
王建华
2019-2-15 15:40:10
你好,
你能为这个查询创建一个技术支持案例吗?这是一个相当复杂的问题,我们想让你加入我们的技术支持团队。
你可以在上面的菜单栏上点击“MyCube”和“GMT”来创建一个案例。
谢谢
以上来自于百度翻译
     以下为原文
   Hi,
    Can you please create a tech-support case for this query? This is a fairly more complicated issue, and we'd like to get you involved with our tech-support team.
    You can create a case by clicking on "MyAccount"->"MyCases" in the menu bar on top..
        thanks
