#define SD_CMD_GO_IDLE_STATE ((uint8_t)0)
#define SD_CMD_SEND_OP_COND ((uint8_t)1)
#define SD_CMD_ALL_SEND_CID ((uint8_t)2)
#define SD_CMD_SET_REL_ADDR ((uint8_t)3) /*!< SDIO_SEND_REL_ADDR for SD Card */
#define SD_CMD_SET_DSR ((uint8_t)4)
#define SD_CMD_SDIO_SEN_OP_COND ((uint8_t)5)
#define SD_CMD_HS_SWITCH ((uint8_t)6)
#define SD_CMD_SEL_DESEL_CARD ((uint8_t)7)
#define SD_CMD_HS_SEND_EXT_CSD ((uint8_t)8)
#define SD_CMD_SEND_CSD ((uint8_t)9)
#define SD_CMD_SEND_CID ((uint8_t)10)
#define SD_CMD_READ_DAT_UNTIL_STOP ((uint8_t)11) /*!< SD Card doesn't support it */
#define SD_CMD_STOP_TRANSMISSION ((uint8_t)12)
#define SD_CMD_SEND_STATUS ((uint8_t)13)
#define SD_CMD_HS_BUSTEST_READ ((uint8_t)14)
#define SD_CMD_GO_INACTIVE_STATE ((uint8_t)15)
#define SD_CMD_SET_BLOCKLEN ((uint8_t)16)
#define SD_CMD_READ_SINGLE_BLOCK ((uint8_t)17)
#define SD_CMD_READ_MULT_BLOCK ((uint8_t)18)
#define SD_CMD_HS_BUSTEST_WRITE ((uint8_t)19)
#define SD_CMD_WRITE_DAT_UNTIL_STOP ((uint8_t)20) /*!< SD Card doesn't support it */
#define SD_CMD_SET_BLOCK_COUNT ((uint8_t)23) /*!< SD Card doesn't support it */
#define SD_CMD_WRITE_SINGLE_BLOCK ((uint8_t)24)
#define SD_CMD_WRITE_MULT_BLOCK ((uint8_t)25)
#define SD_CMD_PROG_CID ((uint8_t)26) /*!< reserved for manufacturers */
#define SD_CMD_PROG_CSD ((uint8_t)27)
#define SD_CMD_SET_WRITE_PROT ((uint8_t)28)
#define SD_CMD_CLR_WRITE_PROT ((uint8_t)29)
#define SD_CMD_SEND_WRITE_PROT ((uint8_t)30)
#define SD_CMD_SD_ERASE_GRP_START ((uint8_t)32) /*!< To set the address of the first write
block to be erased. (For SD card only) */
#define SD_CMD_SD_ERASE_GRP_END ((uint8_t)33) /*!< To set the address of the last write block of the
continuous range to be erased. (For SD card only) */
#define SD_CMD_ERASE_GRP_START ((uint8_t)35) /*!< To set the address of the first write block to be erased.
(For MMC card only spec 3.31) */
#define SD_CMD_ERASE_GRP_END ((uint8_t)36) /*!< To set the address of the last write block of the
continuous range to be erased. (For MMC card only spec 3.31) */
#define SD_CMD_ERASE ((uint8_t)38)
#define SD_CMD_FAST_IO ((uint8_t)39) /*!< SD Card doesn't support it */
#define SD_CMD_GO_IRQ_STATE ((uint8_t)40) /*!< SD Card doesn't support it */
#define SD_CMD_LOCK_UNLOCK ((uint8_t)42)
#define SD_CMD_APP_CMD ((uint8_t)55)
#define SD_CMD_GEN_CMD ((uint8_t)56)
#define SD_CMD_NO_CMD ((uint8_t)64)
* @brief Following commands are SD Card Specific commands.
* SDIO_APP_CMD should be sent before sending these commands.
#define SD_CMD_APP_SD_SET_BUSWIDTH ((uint8_t)6) /*!< For SD Card only */
#define SD_CMD_SD_APP_STAUS ((uint8_t)13) /*!< For SD Card only */
#define SD_CMD_SD_APP_SEND_NUM_WRITE_BLOCKS ((uint8_t)22) /*!< For SD Card only */
#define SD_CMD_SD_APP_OP_COND ((uint8_t)41) /*!< For SD Card only */
#define SD_CMD_SD_APP_SET_CLR_CARD_DETECT ((uint8_t)42) /*!< For SD Card only */
#define SD_CMD_SD_APP_SEND_SCR ((uint8_t)51) /*!< For SD Card only */
#define SD_CMD_SDIO_RW_DIRECT ((uint8_t)52) /*!< For SD I/O Card only */
#define SD_CMD_SDIO_RW_EXTENDED ((uint8_t)53) /*!< For SD I/O Card only */
* @brief Following commands are SD Card Specific security commands.
#define SD_CMD_SD_APP_GET_MKB ((uint8_t)43) /*!< For SD Card only */
#define SD_CMD_SD_APP_GET_MID ((uint8_t)44) /*!< For SD Card only */
#define SD_CMD_SD_APP_SET_CER_RN1 ((uint8_t)45) /*!< For SD Card only */
#define SD_CMD_SD_APP_GET_CER_RN2 ((uint8_t)46) /*!< For SD Card only */
#define SD_CMD_SD_APP_SET_CER_RES2 ((uint8_t)47) /*!< For SD Card only */
#define SD_CMD_SD_APP_GET_CER_RES1 ((uint8_t)48) /*!< For SD Card only */
#define SD_CMD_SD_APP_SECURE_READ_MULTIPLE_BLOCK ((uint8_t)18) /*!< For SD Card only */
#define SD_CMD_SD_APP_SECURE_WRITE_MULTIPLE_BLOCK ((uint8_t)25) /*!< For SD Card only */
#define SD_CMD_SD_APP_SECURE_ERASE ((uint8_t)38) /*!< For SD Card only */
#define SD_CMD_SD_APP_CHANGE_SECURE_AREA ((uint8_t)49) /*!< For SD Card only */
#define SD_CMD_SD_APP_SECURE_WRITE_MKB ((uint8_t)48) /*!< For SD Card only */
