您好,我想问题是这个起动器套件的功耗是高的,因为PHY板您可以尝试以下:1 /电源关闭(删除USB电缆)2 /非常小心地删除包含RJ45连接器的小夹层板(想法是降低PIC的功耗32以太网启动器套件II)3 /后退USB电缆4 /尝试从MPLAB X编程。希望它能管理更新启动器KIT上的固件5/如果这工作,删除USB电缆并将夹层板放回去。希望现在可以编程和调试;=)如果它不工作,我建议。你安装MPLAB X V3.65(你可以保持V3.55,因为它将在另一个目录)。然后从MPLAB X V3.65重新启动以上过程
以上来自于百度翻译
以下为原文
Hi,
I think the issue is the power consumption of this starter kit is high due to the PHY board
Can you please try the following :
1/ Power off (remove USB cable)
2/ Remove very carefully the small mezzanine board which contains the RJ45 connector (the idea is to reduce the power consumption of the PIC32 ethernet starter kit II)
3/ Plug back the USB cable
4/ Try to program from MPLAB X. Hopefully it will manage to update the firmware on the starter kit.
5/ If this works, remove the USB cable and put back the mezzanine board. Hopefully now you can program and debug ;=)
If it does not work, I recommend that you install MPLAB X v3.65 (you can keep v3.55 as it will be in another directory). Then restart above procedure from MPLAB X v3.65
Regards
以上来自于百度翻译
以下为原文
Hi,
Regards
