嗨,你混淆了和谐和MHC插件,这是2个不同的事情。和谐框架是开发你的项目的软件包。当前版本是V2.03BMHC插件,它是插件到MPLAB X的配置和生成项目和代码。MHC插件必须与和声匹配才能正常工作。如杰克所解释的,安装可和谐的MHC插件:C:Microchip 和声 V2Y03B 实用程序 MHCCOM微芯片。-MPLAB-模块-MHCNBMIF已经有一个版本的MHC,卸载它并重新安装上面的一个。最后,确保您使用最新的XC32编译器(V1.44或V1.42,避免V1.43,这可能会影响一些和谐项目)的一些问题。
以上来自于百度翻译
以下为原文
Hi,
You are confusing Harmony and MHC plugin which are 2 different things.
Harmony framework is the SW package to develop your project. Current version is v2.03b
MHC plugin is a plugin addon to MPLAB X to configure & generate projects and code.
MHC plugins MUST be matched with Harmony to work properly.
As explained by jack, install the MHC plugin that is available in Harmony :
C:microchipharmonyv2_03butilitiesmhccom-microchip-mplab-modules-mhc.nbm
If there is already one version of MHC, uninstall it and reinstall the above one.
Finally, make sure you use the latest XC32 compiler (v1.44 or v1.42, avoid v1.43 which has some issues which may affect some Harmony projects)
Regards
以上来自于百度翻译
以下为原文
Hi,
Regards
