你的输出电压是多少?我假设你已经看到了最大值为4.8V的地方没有你威廉希尔官方网站
中没有的外部二极管。如果你试图在没有二极管的情况下超过4.8V,我希望你会遇到问题。无论他们是否永久,我都不能说。
您在哪里找到设置电阻值的信息?我一直试图向ST询问这部分内容。在电话中,他们拒绝回答任何问题,只提到我们的在线提交表格。但是,这不起作用。
以上来自于谷歌翻译
以下为原文
What is your intended output voltage? I assume that you have already seen where the maximum is 4.8V without the external diode which is not present in your circuit. I expect you would have issues if you attempted to go past 4.8V without that diode. Whether or not they are permanent I can't say.
Where did you find the information to set the values of the resistors? I have been trying to ask ST about this part. On the phone they refused to answer any questions and only referred me to their online submission form. However, that doesn't work.
以上来自于谷歌翻译
以下为原文
