您好朋友,我已经使用8514B测试装置将HP8516A opt001 40Ghz参数测试装置集成到我的8510C配置中。
为此,在GPIB和同轴电缆中有两根电缆连接到8516A:1)测试装置互连电缆参考号08516-60102,我已经有了这个,当然是最难获得的。
2)RS232电缆组件参考号08516-60009,我需要这个。
它是两侧的DB25电缆,我猜没什么难的。
有人可以给我这个电缆的图纸,以确定我如何建立它?
该电缆将8516A的“源控制”端口连接到83621B清扫器的源控制端口输出。
这肯定是为了驱动8516A内部的倍增器。
非常感谢您的帮助。
最好的问候Pierre-Francois,F5BQP
以上来自于谷歌翻译
以下为原文
Hello Friends,
I've to integrate a HP8516A opt001 40Ghz parameter test set into my 8510C configura
tion using already a 8514B test set.
To do so there are two cables to attach to the 8516A among GPIB and coax cables:
1) A Test Set Interconnect cable reference 08516-60102 , I already have this one, certainly the hardest to get.
2) A RS232 cable assembly reference 08516-60009, I need this one.
It's a DB25 cable both sides, nothing difficult to build I guess.
Can someone give me the drawing of this cable to be sure how I have to build it?
This cable connects the "Source Control" port from the 8516A to the source control port output from the 83621B sweeper.
This is certainly to drive the doubler which is inside the 8516A.
Many thanks in advance for your help.
Best regards
Pierre-Francois, F5BQP
