Part2:
* Function Name : SD_Init
* Description : ³õʼ»¯SD¿¨
* Input : None
* Output : None
* Return : u8
* 0£ºNO_ERR
* 1£ºTIME_OUT
* 99£ºNO_CARD
u8 SD_Init(void)
u16 i; // ÓÃÀ´Ñ»·¼ÆÊý
u8 r1; // ´æ·ÅSD¿¨µÄ·µ»ØÖµ
u16 retry; // ÓÃÀ´½øÐг¬Ê±¼ÆÊý
u8 buff[6];
//Èç¹ûûÓмì²âµ½¿¨²åÈ룬ֱ½ÓÍ˳ö£¬·µ»Ø´íÎó±êÖ¾
// if(!SD_DET())
// //return 99;
// return STA_NODISK; // FatFS´íÎó±êÖ¾£ºÃ»ÓвåÈë´ÅÅÌ
//SD¿¨Éϵç
// SD_PWR_ON();
// ´¿ÑÓʱ£¬µÈ´ýSD¿¨ÉϵçÍê³É
//Õâ¸öµØ·½Òª¼ÓÒ»¾ä,ÉèÖÃSPIËÙ¶ÈΪµÍËÙ¡£
//ΪʲôÓеĿ¨¿ÉÒÔÄØ£¿ÒòΪSPI³õʼ»¯Ê±ÊǵÍËٵģ¬SD¿¨³õʼ»¯
//Íê³ÉºóÉèÖÃΪ¸ßËÙ£¬ÓеĿ¨Ö»Òª³õʼ»¯Ò»´Î¾ÍÐУ¬³ÌÐò¾Íok£»
//µ«ÓеĿ¨ÐèÒª¶à´Î¸´Î»£¬ºÇºÇ£¬Õâ¸öµØ·½²îÕâÒ»¾ä£¬
//ÕâÖÖ¿¨¾ÍÓò»³É¿©£¡
SPI_SetSpeed(0); //ÉèÖÃSPIËÙ¶ÈΪµÍËÙ
//ÏȲúÉú>74¸öÂö³å£¬ÈÃSD¿¨×Ô¼º³õʼ»¯Íê³É
for(i=0;i<10;i++)
SPI_ReadWriteByte(0xFF);
//-----------------SD¿¨¸´Î»µ½idle¿ªÊ¼-----------------
//Ñ»·Á¬Ðø·¢ËÍCMD0£¬Ö±µ½SD¿¨·µ»Ø0x01,½øÈëIDLE״̬
//³¬Ê±ÔòÖ±½ÓÍ˳ö
SD_CS_ENABLE();
retry = 0;
do
//·¢ËÍCMD0£¬ÈÃSD¿¨½øÈëIDLE״̬
r1 = SD_SendCommand(CMD0, 0, 0x95);
retry++;
}while((r1 != 0x01) && (retry<200));
//Ìø³öÑ»·ºó£¬¼ì²éÔÒò£º³õʼ»¯³É¹¦£¿or ÖØÊÔ³¬Ê±£¿
if(retry==200)
return 1; //³¬Ê±·µ»Ø1
// retry=20;
// do
// r1=SD_SendCommand(CMD0,0,0x95);
// }while((r1!=0x01)&&retry--);
// SD_Type=0;
//-----------------SD¿¨¸´Î»µ½idle½áÊø-----------------
//»ñÈ¡¿¨Æ¬µÄSD°æ±¾ÐÅÏ¢
r1 = SD_SendCommand_NoDeassert(8, 0x1aa, 0x87);
//Èç¹û¿¨Æ¬°æ±¾ÐÅÏ¢ÊÇv1.0°æ±¾µÄ£¬¼´r1=0x05£¬Ôò½øÐÐÒÔϳõʼ»¯
if(r1 == 0x05)
//ÉèÖÿ¨ÀàÐÍΪSDV1.0£¬Èç¹ûºóÃæ¼ì²âµ½ÎªMMC¿¨£¬ÔÙÐÞ¸ÄΪMMC
SD_Type = SD_TYPE_V1;
//Èç¹ûÊÇV1.0¿¨£¬CMD8Ö¸ÁîºóûÓкóÐøÊý¾Ý
//ƬѡÖøߣ¬½áÊø±¾´ÎÃüÁî
SD_CS_DISABLE();
//¶à·¢8¸öCLK£¬ÈÃSD½áÊøºóÐø²Ù×÷
//-----------------SD¿¨¡¢MMC¿¨³õʼ»¯¿ªÊ¼-----------------
//·¢¿¨³õʼ»¯Ö¸ÁîCMD55+ACMD41
// Èç¹ûÓÐÓ¦´ð£¬ËµÃ÷ÊÇSD¿¨£¬ÇÒ³õʼ»¯Íê³É
// ûÓлØÓ¦£¬ËµÃ÷ÊÇMMC¿¨£¬¶îÍâ½øÐÐÏàÓ¦³õʼ»¯
retry = 0;
do
//ÏÈ·¢CMD55£¬Ó¦·µ»Ø0x01£»·ñÔò³ö´í
r1 = SD_SendCommand(CMD55, 0, 0);
if(r1 != 0x01)
return r1;
//µÃµ½ÕýÈ·ÏìÓ¦ºó£¬·¢ACMD41£¬Ó¦µÃµ½·µ»ØÖµ0x00£¬·ñÔòÖØÊÔ200´Î
r1 = SD_SendCommand(ACMD41, 0, 0);
retry++;
}while((r1!=0x00) && (retry<400));
// ÅжÏÊdz¬Ê±»¹Êǵõ½ÕýÈ·»ØÓ¦
// ÈôÓлØÓ¦£ºÊÇSD¿¨£»Ã»ÓлØÓ¦£ºÊÇMMC¿¨
//----------MMC¿¨¶îÍâ³õʼ»¯²Ù×÷¿ªÊ¼------------
if(retry==400)
retry = 0;
//·¢ËÍMMC¿¨³õʼ»¯ÃüÁûÓвâÊÔ£©
do
r1 = SD_SendCommand(1, 0, 0);
retry++;
}while((r1!=0x00)&& (retry<400));
if(retry==400)
return 1; //MMC¿¨³õʼ»¯³¬Ê±
//дÈ뿨ÀàÐÍ
SD_Type = SD_TYPE_MMC;
//----------MMC¿¨¶îÍâ³õʼ»¯²Ù×÷½áÊø------------
//ÉèÖÃSPIΪ¸ßËÙģʽ
SPI_SetSpeed(1);
//½ûÖ¹CRCУÑé
r1 = SD_SendCommand(CMD59, 0, 0x01);
if(r1 != 0x00)
return r1; //ÃüÁî´íÎ󣬷µ»Ør1
//ÉèÖÃSector Size
r1 = SD_SendCommand(CMD16, 512, 0xff);
if(r1 != 0x00)
//-----------------SD¿¨¡¢MMC¿¨³õʼ»¯½áÊø-----------------
}//SD¿¨ÎªV1.0°æ±¾µÄ³õʼ»¯½áÊø
//ÏÂÃæÊÇV2.0¿¨µÄ³õʼ»¯
//ÆäÖÐÐèÒª¶ÁÈ¡OCRÊý¾Ý£¬ÅжÏÊÇSD2.0»¹ÊÇSD2.0HC¿¨
else if( r1 == 0x01)
//V2.0µÄ¿¨£¬CMD8ÃüÁîºó»á´«»Ø4×Ö½ÚµÄÊý¾Ý£¬ÒªÌø¹ýÔÙ½áÊø±¾ÃüÁî
buff[0] = SPI_ReadWriteByte(0xFF); //should be 0x00
buff[1] = SPI_ReadWriteByte(0xFF); //should be 0x00
buff[2] = SPI_ReadWriteByte(0xFF); //should be 0x01
buff[3] = SPI_ReadWriteByte(0xFF); //should be 0xAA
SD_CS_DISABLE();
//the next 8 clocks
//Åжϸÿ¨ÊÇ·ñÖ§³Ö2.7V-3.6VµÄµçѹ·¶Î§
if(buff[2]==0x01 && buff[3]==0xAA)
//Ö§³Öµçѹ·¶Î§£¬¿ÉÒÔ²Ù×÷
retry = 0;
do
if(r1!=0x01)
return r1;
r1 = SD_SendCommand(ACMD41, 0x40000000, 0);
if(retry>200)
return r1; //³¬Ê±Ôò·µ»Ør1״̬
}while(r1!=0);
//³õʼ»¯Ö¸Áî·¢ËÍÍê³É£¬½ÓÏÂÀ´»ñÈ¡OCRÐÅÏ¢
//-----------¼ø±ðSD2.0¿¨°æ±¾¿ªÊ¼-----------
r1 = SD_SendCommand_NoDeassert(CMD58, 0, 0);
if(r1!=0x00)
return r1; //Èç¹ûÃüÁîûÓзµ»ØÕýÈ·Ó¦´ð£¬Ö±½ÓÍ˳ö£¬·µ»ØÓ¦´ð
//¶ÁOCRÖ¸Áî·¢³öºó£¬½ô½Ó×ÅÊÇ4×Ö½ÚµÄOCRÐÅÏ¢
//OCR½ÓÊÕÍê³É£¬Æ¬Ñ¡Öøß
SD_CS_DISABLE();
//¼ì²é½ÓÊÕµ½µÄOCRÖеÄbit30루CCS£©£¬È·¶¨ÆäΪSD2.0»¹ÊÇSDHC
//Èç¹ûCCS=1£ºSDHC CCS=0£ºSD2.0
if(buff[0]&0x40) //¼ì²éCCS
SD_Type = SD_TYPE_V2HC;
else
SD_Type = SD_TYPE_V2;
//-----------¼ø±ðSD2.0¿¨°æ±¾½áÊø-----------
//ÉèÖÃSPIΪ¸ßËÙģʽ
SPI_SetSpeed(1);
return r1;
* Function Name : SD_ReceiveData
* Description : ´ÓSD¿¨ÖжÁ»ØÖ¸¶¨³¤¶ÈµÄÊý¾Ý£¬·ÅÖÃÔÚ¸ø¶¨Î»ÖÃ
* Input : u8 *data(´æ·Å¶Á»ØÊý¾ÝµÄÄÚ´æ>len)
* u16 len(Êý¾Ý³¤¶È£©
* u8 release(´«ÊäÍê³ÉºóÊÇ·ñÊÍ·Å×ÜÏßCSÖÃ¸ß 0£º²»ÊÍ·Å 1£ºÊÍ·Å£©
* Output : None
* Return : u8
* 0£ºNO_ERR
* other£º´íÎóÐÅÏ¢
u8 SD_ReceiveData(u8 *data, u16 len, u8 release)
u16 retry;
u8 r1;
// Æô¶¯Ò»´Î´«Êä
SD_CS_ENABLE();
//µÈ´ýSD¿¨·¢»ØÊý¾ÝÆðʼÁîÅÆ0xFE
retry = 0;
do
r1 = SPI_ReadWriteByte(0xFF);
retry++;
if(retry>2000) //2000´ÎµÈ´ýºóûÓÐÓ¦´ð£¬Í˳ö±¨´í
SD_CS_DISABLE();
return 1;
}while(r1 != 0xFE);
//¿ªÊ¼½ÓÊÕÊý¾Ý
while(len--)
*data = SPI_ReadWriteByte(0xFF);
data++;
//ÏÂÃæÊÇ2¸öαCRC£¨dummy CRC£©
//°´ÐèÊÍ·Å×ÜÏߣ¬½«CSÖøß
if(release == RELEASE)
//´«Êä½áÊø
SD_CS_DISABLE();
return 0;
Part2:
* Input : None
* Output : None
* Return : u8
* 0£ºNO_ERR
* 1£ºTIME_OUT
* 99£ºNO_CARD
u8 SD_Init(void)
u8 buff[6];
// if(!SD_DET())
// //return 99;
//SD¿¨Éϵç
// SD_PWR_ON();
//ÕâÖÖ¿¨¾ÍÓò»³É¿©£¡
for(i=0;i<10;i++)
//³¬Ê±ÔòÖ±½ÓÍ˳ö
SD_CS_ENABLE();
retry = 0;
do
retry++;
if(retry==200)
// retry=20;
// do
// SD_Type=0;
if(r1 == 0x05)
SD_CS_DISABLE();
retry = 0;
do
if(r1 != 0x01)
return r1;
retry++;
if(retry==400)
retry = 0;
do
retry++;
if(retry==400)
//дÈ뿨ÀàÐÍ
//ÉèÖÃSPIΪ¸ßËÙģʽ
SPI_SetSpeed(1);
//½ûÖ¹CRCУÑé
if(r1 != 0x00)
//ÉèÖÃSector Size
if(r1 != 0x00)
SD_CS_DISABLE();
//the next 8 clocks
retry = 0;
do
if(r1!=0x01)
return r1;
if(retry>200)
}while(r1!=0);
if(r1!=0x00)
SD_CS_DISABLE();
else
//ÉèÖÃSPIΪ¸ßËÙģʽ
SPI_SetSpeed(1);
return r1;
* Output : None
* Return : u8
* 0£ºNO_ERR
* other£º´íÎóÐÅÏ¢
u16 retry;
u8 r1;
// Æô¶¯Ò»´Î´«Êä
SD_CS_ENABLE();
retry = 0;
do
retry++;
SD_CS_DISABLE();
return 1;
}while(r1 != 0xFE);
//¿ªÊ¼½ÓÊÕÊý¾Ý
while(len--)
data++;
//´«Êä½áÊø
SD_CS_DISABLE();
return 0;
