嗨,我正在使用由7到8个仪器组成的设置,通过GPIB通过Agilent 82357B(USB / GPIB接口)连接到PC。
它之前一直很好,但是当我从假期回来时,我再也无法工作了。
导致的失败一直是红色的。
故障似乎与82357B本身有关,因为我在不同的PC上尝试了适配器而没有运气。
已将IO库重新安装到最新版本,断开所有仪器,重启几次等等。我再也不会变绿了。
在我缺席期间,我唯一知道的事情是17个新的Windows更新(Win 7)。
这是我在软件方面唯一可以想到的可能影响的东西。
我想这是硬件或硬件。
然而,据我所知,没有其他人触及过这个设置,所以很奇怪..任何有类似经历的人?
所有的帮助表示赞赏,因为这是紧急的。
以上来自于谷歌翻译
以下为原文
Hi,
I'm using a setup consis
ting of 7-8 instruments connected through GPIB to a PC via an Agilent 82357B (USB/GPIB Interface). It has always worked fine before, but when I got back from my vacation I can't get it to work any more. The fail led is constantly red.
The fault seem to be with the 82357B itself, as I have tried the adapter on a different PC with no luck. Have reinstalled the IO Libraries to latest version, have disconnected all instruments, rebooted several times etc. I just won't turn green again.
The only thing I know happend during my absence was 17 new Windows updates (Win 7). That's the only thing I can think of on the software side that possibly could affect. It's either that or broken hardware I guess. However, no one else has touched the setup either as far as I know so it's strange..
Anyone with similar experience? All help is appreciated as this is urgent.
