ST意法半导体
李巍
7年用户 1481经验值
在LIS2MDL上设置新阈值后是否需要最少时间?
嗨,
我试图在LIS2MDL上动态配置中断阈值。似乎有时在设置新阈值后,旧阈值仍然有效并导致输出引脚上的中断转换。在LIS2MDL上设置新阈值后是否需要最少(稳定)时间?
谢谢。
以上来自于谷歌翻译
以下为原文
Hi,
I am trying to dynamically configure the interrupt threshold on the LIS2MDL. It seems that sometimes after setting a new threshold, the old threshold still is in effect and causes an interrupt transition on the output pin. Is there any minimum (settling) time required after setting a new threshold on the LIS2MDL?
Thank you.
回帖(3)
符伯峪
2019-3-4 14:59:28
设置和新测量值是否正确回读?
以上来自于谷歌翻译
以下为原文
Do the settings and new measurements read-back properly?
李巍
2019-3-4 15:14:52
是的,新设置立即从寄存器中读回
以上来自于谷歌翻译
以下为原文
Yes the new settings read back from the registers immediately
李巍
2019-3-4 15:31:51
嗨 - 更新所有人。我已经确定这是我的代码的问题。更新后的设置似乎正确/立即执行。
以上来自于谷歌翻译
以下为原文
Hi - Update to all. I have determined it was an issue with my code. The updated settings do seem to be taking hold correctly/immediately.
