Cypress技术william hill官网
董达勇
7年用户 216经验值
如何得到VDDD=VDDA=5.5V?
我非常肯定VDD开关选择必须在PSoC 3中用3.3V选择,但现在我不确定。
CY8C01-KIT数据表状态PSoC 1家庭必须在5V,但不SAIS NoType特定的PSoC 3。
除此之外,我不知道OpAMPS的电压是多少,我看到的是数据表,但没有太多的信息。
我试了一个跟随者,我得到3.3V作为最大值。
最后:
电源电压板在3.3V时,我如何得到VDDD=VDDA=5.5V?
是因为升压威廉希尔官方网站 吗?
谢谢。
以上来自于百度翻译
     以下为原文
  I was quite sure the Vdd switch select must to be selected with 3.3V in PsOC 3, but now I'm not sure.
    The CY8C001-KIT Datasheet states PsOC 1 family must to be at 5V but don't sais notjing specific for PsOC 3.
    Apart that I don't know what voltage are supplied the OpAmps, I saw the datasheet but is not much information.
    I tried with a follower and I got 3.3V as maximun.
    Finally:
    How can I have the Vddd=Vdda=5.5V when my supply voltage board is at 3.3V?
    Is due to the boost circuit?
    Thanks a lot.
回帖(3)
王浩
2019-3-11 07:27:15
的cy8ckit-001确实有3.3v/5.5v电源开关。检查快速启动指南找到它。
PSoC 3可采用多种方式。值得注意的一点是,VDDA必须是系统中最高的电压。
Vdd的其他可以等于或小于。VDDA可为1.8V至5.5V
如果这是不清楚的,我建议你做需求的培训,特别是在www.cypress.com/ 102系统资源介绍。
希望这有帮助。
以上来自于百度翻译
     以下为原文
  The CY8CKIT-001 does have a 3.3V/5.5V Power Source Switch. Check the Quick Start Guide to locate it.
    PSoC 3 can be powered in many ways. One important thing to note is that Vdda must be the higest voltage in the system.
    Other Vdd's can be equal or less. Vdda can be 1.8V to 5.5V
    If this is unclear, I suggest you do the on demand training , here www.cypress.com/ especially 102 - Introduction to System Resources.
    Hope this helps.
董达勇
2019-3-11 07:42:50
谢谢。你知道OPAPS用户模块是否在VDDA上提供?
以上来自于百度翻译
     以下为原文
  Thanks. Do you know if the OpAmps  User Module are supplied at Vdda?
王浩
2019-3-11 07:56:25
是的,Vdda提供模拟的核心调节器,提供模拟模块和专用的模拟,如放大器。
以上来自于百度翻译
     以下为原文
  Yes, Vdda supplies the analog core regulator, which supplies the analog blocks and dedicated analog, like opamps.
