您好,我们目前通过RS-232端口使用HP-VEE从在线测量设备获取数据。
建议的在线设备升级使用OPC服务器 - 客户端软件和以太网
通信。
使用试用版Agilent VEE PRO 9.2,我的HP-VEE程序(减去数据输入部分)正常工作。我需要了解Agilent VEE是否可以与升级后的设备进行通信而无需设备。可以使用Agilent VEE
Pro 9.2使用TCPIP选项与OPC服务器连接?
如果可以,必须做什么或需要什么信息才能这样做?
谢谢你的帮助。大卫德亚
以上来自于谷歌翻译
以下为原文
Hello,
We currently obtain data from in-line measuring equipment using HP-VEE over an RS-232 port. The proposed in-line equipment upgrade uses OPC server-client software and ethernet communica
tion.
Using a trial version of Agilent VEE PRO 9.2, my HP-VEE program, minus the data input section, works normally.
I need to find out if Agilent VEE can communicate with the upgraded equipment without having the equipment to do so.
Can Agilent VEE Pro 9.2 interface with an OPC server using the TCPIP option? If it can, what has to be done or what information is needed in order to do so? Thanks for your help.
Regards,
David Dea
