你好
我目前正在开发Zynq系统。 我想在开发SDK或Plan Ahead时测量硬件使用(CPU)。 任何回复将不胜感激 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, there I am currently developing a system on Zynq. I would like to measure Hardware Usage(CPU) while developing on SDK or Plan Ahead. Any reply would be appreciated thanks. |
3个回答
您是否在Zynq上使用操作系统?
CPU始终处于使用状态,除非它处于睡眠模式。 如果您使用的是操作系统,则CPU使用率由您花费的时间来定义,而不仅仅是等待下一个任务。 操作系统通常会为您跟踪这些类型的统计信息。 以上来自于谷歌翻译 以下为原文 Are you using an operating system on the Zynq? A CPU is always in use, unless it's in a sleep mode. If you're using an operating system, CPU usage is defined by the amount of time you spend doing something and not just waiting for the next task. Operating systems generally track these sorts of statistics for you. |
哦,我不在Zynq上使用操作系统。你的意思是..在我的代码之间使用一些GetTime()函数会给我CPU使用率?
以上来自于谷歌翻译 以下为原文 oh well i do not use os on the Zynq. so you mean.. using some GetTime() functions between my code would give me the CPU usage? |
不完全是,这会给你时间来做某些功能。
CPU使用率仅在多任务系统的上下文中有意义(或者如果您不时地让CPU进入睡眠状态)。 由你来定义什么是'真正的'CPU使用率和什么是'空闲'(坐在繁忙的循环中,或者是while(true){}循环并等待中断等等。 以上来自于谷歌翻译 以下为原文 Not quite, that'll give you the time it took to do certain functions. CPU usage only makes sense in the context of a multi-tasking system (or perhaps if you're putting the CPU to sleep from time to time). It's up to you to define what is 'real' CPU usage and what is 'idle' (sitting in a busy loop, or a while(true){} loop and waiting for interrupts, etc.). |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1777浏览 1评论
623浏览 1评论
485浏览 1评论
2036浏览 0评论
762浏览 0评论
GMT+8, 2025-1-13 14:25 , Processed in 1.284959 second(s), Total 81, Slave 65 queries .
