嗨,你能在两台机器上分享lmutil lmstat的输出吗?谢谢,Vinay
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hi,
Can you share the output of lmutil lmstat on both machines?
Thanks,
Vinay--------------------------------------------------------------------------------------------
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
如果没有,你应该在发布之前。
以上来自于谷歌翻译
以下为原文
Hi,
Thanks,
