IAR STM8编译器是否适用于STVD?
以上来自于谷歌翻译 以下为原文 Does IAR STM8 complier work with STVD? |
5个回答
http://www.cosmic-software.com/stm8.php
所以,如果你真的想使用STVD,你可以。我个人使用IAR的EWSTM8产品,因为我们使用其他IAR产品,我更喜欢STVD / Cosmic。 以上来自于谷歌翻译 以下为原文 http://www.cosmic-software.com/stm8.php so if you really want to use STVD you can. Personally I use IAR's EWSTM8 product as we use other IAR products and I prefer it to STVD/Cosmic. |
首先,谢谢你的兴趣。我问我的奇迹。我正在使用STVD
先前。 我赞同你。我更喜欢IAR Studio。因为,宇宙并不是很好。简单地说;宇宙发现错误。但找不到发生错误的行。 可以问一个问题吗?什么是差异IAR输出(英特尔扩展和英特尔标准)? 以上来自于谷歌翻译 以下为原文 Firstly,Thank you for instrest. I asked for my wonder. I was using STVD previously. I agree with you. I prefer IAR Studio. Because, Cosmic is not very well complier. Simply Exmaple ; Cosmic find errors. But can not find line that error occur. Can ı ask a question ? What is difference IAR outputs(intel extended and intel standart)? |
早在1970/80年代创建的原始Intel-Hex文件格式仅允许16位地址(总共65,536字节)。扩展十六进制允许32位地址。由于STM8具有24位地址空间,即使某些设备不使用它,我仍然坚持使用Extended-Hex格式。
http://www.keil.com/support/docs/1584.htm 以上来自于谷歌翻译 以下为原文 The original Intel-Hex file format, created back in 1970/80's, only allowed for 16-bit addresses (65,536 bytes total). The Extended-Hex allows 32-bit addresses. Since the STM8 has a 24-bit address space, even though some devices don't use it, I'd stick with the Extended-Hex format. http://www.keil.com/support/docs/1584.htm |
***************** 你说什么的一个例子? 卢卡 以上来自于谷歌翻译 以下为原文 Simply Exmaple ; Cosmic find errors. But can not find line that error occur. ***************** An example of what you say? Luca |
嗨卢卡,
我用了三年的COSMIC ST7。我在这个计划中创建了很多项目。 示例:Cosmic在未在命令行的en处放置分号时出错。然后单击错误下方。但是COSMIC不会让你错误地命令行。我多次遇到这种情况。 你有解决这个问题的解决方案吗? 以上来自于谷歌翻译 以下为原文 Hi Luca, I have used COSMIC ST7 three years. And I have created many project in this program. Example : Cosmic gives error when not put semicolon at the en of the command line. Then click below the error. But COSMIC will not take you to incorrectly command line. I encountered this situation many times. Do you have an solution that regard this problem? |
2783 浏览 1 评论
3252 浏览 1 评论
1826 浏览 1 评论
3672 浏览 6 评论
6065 浏览 21 评论
1350浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
374浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
470浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
294浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
218浏览 2评论
GMT+8, 2025-1-13 18:18 , Processed in 1.608558 second(s), Total 83, Slave 67 queries .
