您好@ndenier,您是否从上述链接获得了您要查找的信息?如果是,请通过标记解决方案来关闭该线程。
谢谢,维杰-----------------------------------------------
---------------------------------------------请将帖子标记为
一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。
以上来自于谷歌翻译
以下为原文
Hi @ndenier,
Did you get the information you are looking for from the above link?
If yes, please close the thread by marking the solution.Thanks,Vijay
Please mark the post as an answer "Accept as solution" in case it helped resolve your query.
Give kudos in case a post in case it guided to the solution.
以上来自于谷歌翻译
以下为原文
Hi @ndenier,
