为了检查我启动了MPLAB 8.84,我的最后一个项目出现了。在MPLAB 8中有菜单项来选择工具套件并设置工具套件的位置。但是XC16 1.31(上星期刚安装的一个)已经在这个环境中存在,而我不需要做任何事情。ST可以通过在语言工具选择框中选择它来切换它。这真的让我吃惊,在这种情况下MPLAB-X如何不知道编译器…卸载和重新安装有什么好处?在MPLAB-X中是否要求编译器安装在“C:程序文件”下面?这是我的系统开发工具中的NO!在MPLAB-X上存储编译器位置的确切位置是什么?编辑:我在我的计算机上查看了注册表,发现:HKEY-CurrTyAuth[SufficeMicrochip LoalGotoOsLxC16]这里写的是XC16的当前位置,所以信息肯定是存在的!为什么MPLAB-X不把它捡起来?
以上来自于百度翻译
以下为原文
In order to check I started MPLAB 8.84 and my last project appeared there.
In MPLAB 8 there are menu items to select the tool suite and to set the location of a tool suite.
But XC16 1.31 (the one I just installed last week) is already present in this environment without me having to do anything, I just can switch the project to it by selecting it in the language tool selection box.
It really beats me how MPLAB-X in such a situation can be unaware of the compiler...
What good would uninstalling and re-installing do?
Is there a requirement in MPLAB-X that the compiler is installed below "C:Program Files"?
That is a no-no in my system for development tools!
Where exactly is the compiler locations stored on MPLAB-X?
EDIT:
I looked in the Registry on my computer and found this:
HKEY_CURRENT_USERSoftwareMicrochipLanguageToolsXC16
Here is written the current location of XC16, so the information is for sure present!
Why does MPLAB-X not pick it up?
以上来自于百度翻译
以下为原文
EDIT:
