3个回答
将算法转换为逻辑兼容模式。学习VHDL / Verilog / HLScodes仿真并比较/纠正程序FPGAEasy
以上来自于谷歌翻译 以下为原文 transpose the algorithum into a Logic compatible mode. learn VHDL / Verilog /HLS code simulate and compare / correct program FPGA Easy |
@kdeepakkartik
编写RTL描述,添加/创建源文件并运行XST-MAP-P& R以生成用于FPGA编程的比特流。 使用ISE工具来定位Spartan系列。 谢谢,Anusheel ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - - 搜索 在william hill官网 上发布查询之前,与您的设备和工具相关的文档/答案记录。搜索相关william hill官网 并确保您的查询不会重复。请将帖子标记为“接受为解决方案”,以防它有助于解决您的查询。帮助 回答 - >给予Kudos --------------------------------------------- -------------------------------------------------- 以上来自于谷歌翻译 以下为原文 @kdeepakkartik Write the RTL description, add/create the source files and run XST-MAP-P&R to generate bitstream for FPGA programming. Use ISE tool to target Spartan family. Thanks, Anusheel ----------------------------------------------------------------------------------------------- Search for documents/answer records related to your device and tool before posting query on forums. Search related forums and make sure your query is not repeated. Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
唉HLS不支持任何斯巴达人。
即便如此,我确信可以按摩最终的hdl来删除7系列细节,以便在spartan3上运行; 也许:-) dsp48e1可能是最困难的。 也许如果没有乘数? 无论如何,GA通常不需要它们。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 Alas HLS doesn't support any spartans. Even then, I am sure one can massage the resulting hdl to remove 7 series specifics to make something work on spartan3; maybe :-) dsp48e1 is probably most difficult. maybe if there were no multipliers? GAs usually don't need them anyway.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1775浏览 1评论
623浏览 1评论
485浏览 1评论
2036浏览 0评论
762浏览 0评论
GMT+8, 2025-1-13 11:05 , Processed in 1.515445 second(s), Total 81, Slave 65 queries .
