芯片求购|供应发布区
胡工
6年用户 1788经验值
[供应]
韩国HITROL料位开关 HCC-95PW
`韩国HITROL料位开关 HCC-95PW      韩国HITROL料位开关 HCC-95PW
代理韩国HITROL浮球液位开关
吴工:0755-26998458/ 132,4667,5433
工作Q: 1139878854
HITROL
HT-100RV,HR-30V-2F,HR-30V-4F,HLC-200,HLC-300,HTA-2004,HLC-901L,HFS-2T,HM-12S,HT-100RSH
HTM-930,HLC-901P,HT-100R,HT-100CT-2,HQ-66S-3F,HT-100RTH,HR-30TH-2F-EX,HLV-300,HLV-310,
HT-100CTH-2,HT-100CTWH-2,HTM-20M-A,HTM-20N,HT-100PT,HT-100RS-EX,HR-30S-2F,HR-30SH-2F,
HQ-66-3F,HCC-96RF-SH,HCC-96RF-S,HR-30C-4F,HM-90-2F,HM-30-1F,HCC-95RF-C,HR-30S-3F,HTM-901,
RT14-20,HR-30S-1F-EX,HR-30S-3F-EX,HTM-20N-A,HQ-66-4F,HCC-75P,HR-30S-5F,HCC-609N-FS,
HR-10S-1F,HR-30S-1F,HR-30S-2F-EX,HR-30T-2F,HM-90-1F-EX,HT-100RT,HT-100RT-EX,HQ-36-1F,
HQ-36-2F,HQ-36-3F,HR-30TS-3F-EX,HSC-10TT-1F,HR-30TH-2F,HCC-75R-FS,HTM-929,HR-30S-4F,
HT-100R R/I,HTA-2002,HTA-2003,HTA-2004-1111,HTA-4003,HTA-4004,HI-100A,HI-100S,HT-100FI
HI-150S,HI-200AL,HI-200AL-EX,HLC-24P,HT-200PD,HM-100,HT-200PG,HFC-6532G,HFC-6532S,
HHT-2000,W-100,H-400,H-500,HSP-300,HS-300,HS-400,HP-200,HRM-100,HUL-2000N,HUT-2000N,
HUL-2000T,HUL-2000S,HUT-2000T,HUT-2000S,HT-100F,HM-95,HM-90S,HR-30,HM-12,HM-10,
HQ-66,HQ-36,CS-1000-Ex,HQM-77,HR-10,HR-50,HR-10L,HM-30,HM-90,HT-200C,HCC-95P,HPC-95P,
HCC-75R,HPC-95R,HCC-609N,HPC-609N,HPC-100CT-2,HT-100C-2,HT-100CT,HPC-100CT,
HCC-96RF-R,HPC-96RF-R,HPV-20N,HTM-920,HTM-921,HNV-970,HTM-230,
HTM-330,HTM-430,HP-1A,HE-1S,HFW-100W,HTG-200,HTG-100,HT-100W,HLG-100F,HTML-TC,
HTML-TM,HTML-S,HFR-981,HFT-7000,HMF-800,HUT-3000,HUT-2001S,HUL-2200S,
HUL-2300S,HUL-2100N,HUL-2100S,HUL-2100T,HT-100PS,HCC-96RF,HQQ-66,
HQQ-77,HLT-1110,HLT-2110,HTG-100S,HTG-200D,HUL-2100,HTM-920
HUL-2300,HUL-2200,HT-100R-EX,HT-100RH,HT-100RH-EX,HT-100RS,HT-100RS-L,
HT-100RSH,HT-100RSH-EX,HT-100RSH-L,HT-100RT-L,HT-100RTH-EX,
HT-100RV-EX,HT-100RV-L,HT-100FI,HM-95-EX,HM-95H,HM-95H-EX,HM-95V,HM-95V-EX,
HM-95VH,HM-95VH-EX,HM-90S-EX,HM-90SH,HM-90SH-EX,HR-30-Ex,HR-30C,HR-30C-EX,HR-30CH,
HR-30CH-EX,HR-30H,HR-30H-Ex,HR-30S,HR-30S-EX,HR-30SH,HR-30SH-EX,HR-30T,HR-30T-EX,HR-30TH,
HR-30TH-EX,HR-30V,HR-30V-EX,HM-12D,HM-12H,HM-12H-EX,HM-12H-L,HM-12H-L-EX,HM-12H-SP,
HM-12H-SP-EX,HM-12S,HM-12W,HQ-3,HQ-6,HQ-66P,HQ-66S,HQM-7,HQM-77P,HR-10S,HR-10T,HR-10L-Ex,
HM-90-EX,HM-90H,HM-90H-EX,HLC-200C-L,HT-200CT-2,HCC-95PH,HCC-95PW,HCC-95PWH,HPC-95PH,
HPC-95PW,HPC-95PWH,HCC-75RD,HCC-75RDH,HCC-75RH,HCC-75RW,HCC-75RWH,HLC-75R-L,HLC-75R-P,
HPC-95RH,HPC-95RW,HPC-95RWH,HCC-609N-RD,HCC-609NH,HCC-609NW,HCC-609NWH,HPC-609NH,
HPC-609NW,HPC-609NWH,HT-100CTW-2,HPC-100CTH-2,HPC-100CTW-2,
HPC-100CTWH-2,HT-100CH-2,HT-100CW-2,HT-100CWH-2,HLC-100C-P,HPC-100CTH,HPC-100CTW,
HPC-100CTWH,HT-100CTH,HT-100CTW,HT-100CTWH,HCC-95RF-CH,HCC-96RF-RH,HLC-96RF-R,
HLC-96RF-RACK,HPC-96RF-RH,HPV-20N-A,HPV-20N-B,HPV-20NH-A,HPV-20NH-B,
HTM-20N-B,HTM-20N-C,HTM-20NH-A,HTM-20NH-B,HLC-901-L,HLC-901-P,HLC-900-L,HLC-900-P,
HTM-920H,HTM-921H,HLC-970-L,HE-2D,HE-2H,HE-2V,HE-3H,HE-3H-S,HE-3H-SP,HE-3S,HE-3V,HE-4H,
HE4H-S,HE-4H-SP,HE-4S,HE-4V,HE-5H,HE-5H-S,HE-5H-SP,HE-5S,HE-5V,HE-6V,HE-7V,HLV-300-EX,
HLV-300H,HLV-310AP,HLV-310H,HLV-310HP,HLV-320L,HM-100A,HM-100S,HM-100V,HLT-1112,
HMF-800R,HMF-800S,HOP-C,HKOP-F,HKOP-N,HHG-1FA,HHG-1FB,HHG-2FA,HHG-2FB,
HMO-0080,HMO-0100,HMO-0150,HMO-0250,HMO-0300,HRO-0015FW,HRO-0020FW,HRO-0025FW,HRO-0040FW,
HRO-0050FW,HRO-0065FW,HRO-0080FW,HRO-0100FW,HRO-0125FW,HRO-0150FW,HRO-0200FW,HRO-0250FW,
HRO-0300FW,HRO-0350FW,HRO-0400FW,HRO-0450FW,HRO-0500FW,HRO-0550FW,HRO-0600FW,HRO-1800FW,
HRO-0080MW,HRO-0025CW,HRO-0040CW,HRO-0050CW,HRO-0065CW,HRO-0080CW,HRO-0100CW,HRO-0125CW,
HRO-0150CW,HRO-0200CW,HRO-0250CW,HRO-0300CW,HRO-0350CW,HRO-0400CW,HRO-0450CW,HRO-0500CW,
HRO-0550CW,HRO-0600CW,HRO-0900CW,HOF-0025,HOF-0040,HOF-0050,HOF-0080,HOF-0100,
HOF-0125,HOF-0150,HOF-0200,HOF-0250,HOF-0300,HOF-0350,HOF-0400,HOF-0450,HOF-0500,
HOF-0550,HOF-0600,HOF-0650,HOF-0700,HOF-0750,HOF-0800,HOF-0850,HOF-0900,HOF-I-0015,
HC-5300-F,HC-5300-S,HC-5600-F,HC-5600-S,HC-5900-F,HC-5900-S,HC-5V15-F,HC-5V15-S,
HC-6150-F,HC-1515-S,HC-2150-F,HC-2150-S,HC-2300-F,HC-2300-S,HC-2V15-F,HC-2V15-S,
HC-3150-F,HC-3150-S,HC-3300-F,HC-3300-S,HC-3600-F,HC-3600-S,HC-3900-F,HC-3900-S,
HC-3V15-F,HC-3V15-S,HC-4150-F,HC-4150-S,HC-4300-F,HC-4300-S,HC-4600-F,HC-4600-S,
HC-4900-F,HC-4900-S,HC-4V15-F,HC-4V15-S,HFV-0015,HFV-0020,HFV-0025,HFV-0032,HFV-0040,
HFV-0050,HFV-0065,HFV-0080,HFV-0100,HFV-0125,HFV-0150,HFV-0200,HFV-0250,HFV-0300,
HFV-0350,HFV-0400,HFV-0450,HFV-0500,HFV-0550,HFV-0600,HFV-0650,HFV-0700,HFV-0750,
HFV-0800,HFV-0850,HFV-0900,HFV-0950,HFV-1000,HFV-1050,HFV-1100,HFV-1150,HFV-1200,
HITROL液位开关的类型有以下几种:
不锈钢浮球开关
通用型不锈钢浮球液位开关提供竖直与水平安装两种配置,采用1路30VA或100VAh开关输出,能可靠地对相对洁净的水、稀释化学品和轻质油进行液位探测。适用介质包括去离子热水和食用油。不锈钢液位传感器可竖直安装在储罐内或水平安装在罐壁上,用于高液位或低液位报警
连杆浮球液位开关
连杆浮球液位开关套装能可靠地对相对洁净的水、稀释化学溶剂和轻质油进行多点液位探测,最大量程为8'(2.44米)。采用1-5路开关输出,一体式集装接线盒内有集成接线终端。浮球液位开关采用不锈钢材料,适用于高温或高压过程储罐的液位测量。
磁浮球液位开关
浮球开关常被应用在储罐液位的控制上。没有外接电源,侧边或顶部安装,宽的温度压力范围,多种多样的过程连接,不锈钢接液部分和防爆设计,适用范围广。
侧装浮球开关
磁性侧装浮球开关常被应用在储罐液位的控制上。侧装浮球开关没有外接电源,侧边或顶部安装,宽的温度压力范围,多种多样的过程连接,不锈钢接湿部分和防爆设计使其成为普遍适用的浮球液位开关。
电缆浮球液位开关
浮球液位开关 拥有两个腔室,在加工电缆浮球开关的时候使用特殊工艺使之完全密封。通过电缆端头的平衡锤可调整不同的开关点。无毒性和无汞性使电缆浮球液位开关可以应用于饮用水中。
多点不锈钢浮球开关
浮球开关用于FM和CSA认证的防爆应用和一般环境应用。浮球开关最多提供4个开关点,可用于PLC或SCADA远程设备检控。多点不锈钢浮球开关典型应用在高温和/或高压过程罐并且需要防爆认证的环境。
液位开关主要由磁簧开关和浮子组成,浮子内有磁性材料,浮子随被测液位上下移动时,触动磁簧开关而检出液位位置。液位开关在汽车、工业设备、农用设备、家用电器中应用前景十分广泛。
小型浮球开关是一种结构简单,使用安装方便的液位控制器。它没有复杂的威廉希尔官方网站 ,不会受到干扰,只要材质选用正确,在任何环境下液体、压力或是温度皆可使用。体积轻巧、工作原理简单、可靠性高、便宜
附件: 您需要登录才可以下载或查看附件。没有帐号?注册
