参考:STM8S发现示例:
http://www.st.com/stonline/products/support/micro/files/um0834.zip
所有示例项目(ADC,PWM或Discovery)都不包含“Raisonance”项目文件夹中的任何内容。
从'Cosmic'项目文件夹打开文件选择'Cosmic'作为工具集 - 即使PC上没有Cosmic!
如果工具集更改为“Raisonance”,则项目无法构建!
他们无法建立,因为他们可以找到'stm8s.h'
问题似乎是STVD无处指定包含路径 - 似乎只能相对于Toolset安装文件夹指定它们! : - |
这些项目是否真的应该与Raisonance合作?
如果没有,那么为什么提供了Raisonance文件夹?
为什么Discovery用户手册中没有提到这一点?
以上来自于谷歌翻译
以下为原文
Ref: the STM8S Discovery Examples:
None of the example projects - ADC, PWM, or Discovery - contains anything in the 'Raisonance' project folder.
Opening the file from the 'Cosmic' project folder selects 'Cosmic' as the toolset - even when Cosmic is not present on the PC!
If the toolset is changed to 'Raisonance', of the projects fail to build!
They fail to build because of them can find 'stm8s.h'
The problem seems to be that STVD has nowhere to specify include paths - it only seems possible to specify them relative to the Toolset installation folder!! :-|
Are these Projects actually supposed to work with Raisonance at all?
If not, then why is there a Raisonance folder provided?
Why is this not mentioned in the Discovery user manual?
参考:STM8S发现示例:
以上来自于谷歌翻译
以下为原文
