CHINO KR2S6P-N8A记录仪 CHINO KR2S6P-N8A记录仪
代理日本CHINO记录仪
吴经理:0755-26998458/132,4667,5433
工作Q:11398788
日本 CHINO 型号:
KR2160-N0A,KR2120-N0A,KR2161-N0A,KR2121-N0A,KR3120-N0A,KR3140-N0A,KR3160-N0A,KR3180-N0A,KR3121-N0A,KR3141-N0A,
KR3161-N0A,KR3181-N0A,KR2160MN0A-1NN,KR2120MN0A-1NN,
KR2161MN0A-1NN,KR2121MN0A-1NN,KR3S21-N0A-NNN,KR3S41-N0A-NNN,KR3S61-N0A-NNN,KR3S81-N0A-NNN,KR3120-N0A-1NN,KR3140-N0A-1NN,
KR3160-N0A-1NN,KR3180-N0A-1NN,KR3121-N0A-1NN,KR3141-N0A-1NN,KR3161-N0A-1NN,KR3181-N0A-1NN,KR2P60MN0A,KR2P20MN0A,
KR2P61MN0A,KR2P21MN0A,KR3P20-N0A,KR3P40-N0A,KR3P60-N0A,KR3P80-N0A,KR3P21-N0A,KR3P41-N0A,KR3P61-N0A,KR3P81-N0A,
AL4706-N0A-NNN,AL471P-N0A-NNN,AL472P-N0A-NNN,AL473P-N0A-NNN,AL474P-N0A-NNN,KL4106-N0A,KL4206-N0A,KL4506-N0A,KR2S2P-N0A,
KL4606-N0A,AH4706-N0A-NNN,AH4712-N0A-NNN,AH4724-N0A-NNN,AH471P-N0A-NNN,AH472P-N0A-NNN,AH473P-N0A-NNN,AH474P-N0A-NNN,
KR2S6P-N0A,KR2S2P-N0A,AL4706-N0A-NNN,AH4706-A0A-NNN,CP970-01,SHIN-EI,CP960-03ELSD25-000,ELSD35-000,DB1030B000-G0A,
DB1050B000-G0A,KP1030C000-G0A,KP1050C000-G0A,KR2160-N0A,KR2161-N0A,KR2121-N0A,KR3120-N0A,KR3120-N0A,KR2120-N0A,
KR3140-N0A,KR3160-N0A,KR3180-N0A,KR3121-N0A,KR3141-N0A,DZ1030-000KR3161-N0A,KR3181-N0A,KR2160MN0A-1NN,KR2120MN0A-1NN,AH3725-A00
KR2161MN0A-1NN,KR2121MN0A-1NN,KR3S21-N0A-NNN,KR3S41-N0A-NNN,DZ1030-010KR3S61-N0A-NNN,KR3S81-N0A-NNN,,KR3140-N0A-1NN,
AL471P-N0A-NNN,AL472P-N0A-NNN,AL473P-N0A-NNN,AL474P-N0A-NNN,KL4106-N0A,KL4206-N0A,KL4506-N0A, AH3760-N00 AH3765-NOO
日本CHINO混合式存储记录仪(打点式)AH4000、AL4000系列
AH4706-NOA-NNN、AH4712-NOA-NNN、AH4724-NOA-NNN、AH4706-EOA-NNN、AH4706-ROA-NNN、AH4706-AOA-NNN、AH4712-EOA-NNN、AH4712-ROA-NNN、
AL4706-NOA-NNN、AL4706-EOA-NNN、AL4706-ROA-NNN、AL4706-N2A-NNN、AL4706-E2A-NNN、AL4706-E4A-NNN、AL4706-ROA-NNN、AL4706-AOA-NNN、
AH4712-EOA-NNP、AH4712-NOA-NNP、AH4712-ROA-NNP、AH4724-EOA-NNP、AH4724-ROA-NNP、AH4724-E2A-NNN、AH4724-ROA-NNP、AH4724-R2A-NNN
AL471P-NOA-NNN、AL471P-EOA-NNN、AL471P-ROA-NNN、AL471P-AOA-NNN、AL471P-N2A-NNN、AL471P-N4A-NNN、AL472P-NOA-NNN、AL472P-EOA-NNN、
AL472P-ROA-NNN、AL473P-ROA-NNN、AL473P-NOA-NNN、AL473P-EOA-NNN、AL471P-ROA-NNN、AL473P-N2A-NNN、AL474P-NOA-NNN、AL474P-EOA-NNN
AH471P-NOA-NNN、AH471P-N2A-NNN、AH471P-N4A-NNN、AH471P-EOA-NNN、AH471P-ROA-NNN、AH471P-AOA-NNN、AH471P-E2A-NNN、AH471P-E4A-NNN、
AH472P-NOA-NNN、AH472P-N2A-NNN、AH472P-NAA-NNN、AH472P-EAA-NNN、AH472P-ROA-NNN、AH473P-ROA-NNN、AH474P-ROA-NNN、AH473P-NOA-NNN
AH3720-N00 AH3720-N20 AH374P-N00-00A
KR2S6P-NOA、 KR2S6P-N2A、KR2S6P-N7A、KR2S6P-N8A、KR2S6P-E0A、KR2S6P-E2A、KR2S6P-E8A、KR2S6P-E0T、KR2S6P-R0A、KR2S6P-R2A
KR2S6P-R7A、 KR2S6P-R0T、KR2S6P-R8A、KR2S6P-R0T、KR2S6P-G0A、KR2S6P-G2A、KR2S6P-GTA、
KR2S2P-NOA、 KR2S2P-N2A、KR2S2P-N7A、KR2S2P-N8A、KR2S2P-E0A、KR2S2P-E2A、KR2S2P-E8A、KR2S2P-E0T、KR2S2P-R0A、KR2S2P-R2A
KR2S2P-R7A、 KR2S2P-R0T、KR2S2P-R8A、KR2S2P-R0T、KR2S2P-G0A、KR2S2P-G2A、KR2S2P-GTA、
数字式指示调节仪DB1000/DB2000系列
DB1010B000-GOA、DB1410B000-G0A DB1020B000-G0A、DB1420B000-G0a DB1030B000-G0A、DB1430B000-G0A DB1031B000-G0A、DB1020BS01-G0A
DB1030BS00-G0A、DB1010BS00-G0A DB1050B000-G0A、DB1450B000-G0A DB1060B000-G0A、DB1460B000-G0A DB1080B000-G0A、DB1480B000-G0A
DB20100000-GOA、DB24100000-GOA DB20200000-GOA、DB24200000-GOA DB20300000-GOA、DB24300000-GOA DB20500000-GOA、DB24500000-GOA
DB20600000-GOA、DB24600000-GOA DB20800000-GOA、DB24800000-GOA
图形记录仪KR3000系列
KR3000系列采用可视性优异的12.1型TFT彩色液晶屏和触摸面板操作方式,是兼顾高功能和操作性的适用于网络的无纸记录仪。
实现了采集周期约100ms/48点、精度为+-0.1%的高速、高精度,测量数据可保存在内存及最大8GB的小型闪存卡(CF卡)中。
可直接用触笔写入画面。
采用触摸面板。
多彩的记录方式、操作简单。
支持LAN环境网络。
备有解析、数据采集用的应用软件。
KR3120-NOA、KR3140-NOA、KR3160-NOA、KR3180-NOA、KR3121-NOA、KR3141-NOA、KR3161-NOA、KRR3181-NOA
图形记录仪KR2S系列
KR2S6P-NOA、KR2S12P-NOA
热电偶(TC)W-WRe26、WRe5-WRe26、PtRh40-PtRH20、NiMo-Ni、CR-AuFe、Pla
tinel II、PT100、JPT100、PT50、Pt-Co
KR2P00/KR3P00是一种遵循医药产品制造业FDA 21CFRPart11要求、用于数据记录的搭载防篡改功能的无纸记录仪。
具有丰富的显示画面和高级功能,简单操作即可进行数据记录和管理。标配以太网,支持网络环境。可向USB存储器传输数据。
图形记录仪KR2P00/KR3P00
KR2960MN0A、KR2P20MN0A、KR2P61MN0A、KR2P21MN0A、KR3P20-NOA、KR3P40-NOA、KR3P60-NOA、KR3P21-NOA、KP3P41-NOA、KR3P61-NOA、KR3P81-NOA
AH、AL4000系列,是配备LCD数字显示,测量值清晰醒目的混合式记录仪。
将测量数据记录在纸上的同时,还能保存到SD卡的180MM记录纸(AH4000)、100MM记录纸(AL4000)的记录仪。
可通过正面的按键开关进行简单设定。
图形LCD显示。
标配演算功能。
标准附带软件包。
AL4706-NOA-NNN
混合式记录仪(打点式)KH4000、KL4000系列
KH4106-NOA、KH4206-NOA、KH4506-NOA、KH4606-NOA
KL4106-NOA、KL4206-NOA、KL4506-NOA、KH4606-NOA
ELS系列是记录宽度100MM的模拟式记录仪。只需进行输入和
电源的接线,即可开始记录,操作也简单。
备有1,2,3,6点的打点式和1,2,3笔式。
100V~240V AC(50/60HZ)电压范围的自由电源。
模拟式记录仪ELS系列
ELSP15-000、ELSP17-000 、ELSD15-000、ELSD17-000
ELSF00N-00、ELSG000-00
ES600系列虽是记录宽度60MM的小型规格,却是具有高可靠性大型记录仪同等功能的模拟式记录仪。
记录方式备有单点连续记录的笔式和1,2,3,6点的打点式。
96*144MM的小巧轻盈。
