Microchip
宋玉红
7年用户 195经验值
什么是可升级的字段?
嗨,大家能通过UART来解释什么是可升级的字段吗?我只限于ISSC蓝牙闪存工具和使用GUI更新模块吗?是否有任何ISSC闪存工具是命令行驱动来自动化固件升级过程?我认为它也没有OTA选项的模块,如RN4020?谢谢
以上来自于百度翻译
      以下为原文
    Hi all,
Can someone explain what field upgradable via UART actually means?
Am I limited only to the ISSC Bluetooth Flash Tool and updating the module using the GUI?
Are there not any ISSC flash tools that are command line driven to automate the firmware upgrade process?
I take it also there is no OTA option for the module like the RN4020?
Thanks
回帖(1)
魏茂娜
2019-4-17 16:15:35
在UART上可升级的字段意味着您可以插入USB到串行适配器,并切换ROM/EEPROM引脚,以便能够在现场编程,或者在UART和GPIO上与微控制器进行相同的操作。我没有发现BM20 BM91模块的OTA功能。
以上来自于百度翻译
      以下为原文
    Field upgradable over Uart means that you can either plug a USB to Serial adapter in and toggle the ROM/EEPROM pins to be able to program it in the field or do the same with a microcontroller over uart and gpio.
I have not found any OTA functionality for the BM20-BM71 modules.
