您好,我已经安装了Agilent Connection Expert 16.0,并且我安装了IVI Shared Components 2.1.1。
我试图通过运行:instrhwinfo('ivi')验证共享组件是否已安装在matlab R2010B中这导致以下错误:??? 使用==> iviconfigurationstore.iviconfigurationstore时出错> iviconfigurationstore.iviconfigurationstoreat 40无法访问IVI配置服务器。==> instrhwinfo中的错误> 476store = iviconfigurationstore中的localFindIVIDrivers;错误==> instrhwinfo at 189 out = localFindIVIDrivers;我注意到我 尝试查找IVI配置存储时失败。 如果有一些我错过的步骤,你能告诉我吗?谢谢你,Dylan Bespalko 以上来自于谷歌翻译 以下为原文 Hello, I have installed Agilent Connection Expert 16.0 and I have installed the IVI Shared Components 2.1.1. I am trying to verify that the Shared Components have been installed in Matlab R2010B by running: instrhwinfo ('ivi') This results in the following error: ??? Error using ==> iviconfigurationstore.iviconfigurationstore>iviconfigurationstore.iviconfigurationstore at 40 The IVI Configuration Server could not be accessed. Error in ==> instrhwinfo>localFindIVIDrivers at 476 store = iviconfigurationstore; Error in ==> instrhwinfo at 189 out = localFindIVIDrivers; I notice that i fails when it tries to find the IVI Configuration Store. Can you please tell me if there are some steps that I have missed? Thank you, Dylan Bespalko |
另一项检查是从Matlab提示符运行'tmtool'并检查Instrument Drivers-> IVI选择,然后检查Software Modules选项卡。
是否列出了您尝试使用的驱动程序?在窗口顶部,您还将看到IVI配置存储的路径。 确保您可以访问此文件。 以上来自于谷歌翻译 以下为原文 Another check would be to run 'tmtool' from the Matlab prompt and examine the Instrument Drivers->IVI selection and then the Software Modules tab. Is the driver you are trying to use listed? At the top of the window you will also see the path to your IVI Configuration Store. Make sure you can access this file. |
1317 浏览 0 评论
2389 浏览 1 评论
2208 浏览 1 评论
2080 浏览 5 评论
2964 浏览 3 评论
1207浏览 1评论
776浏览 0评论
1008浏览 0评论
1321浏览 0评论
GMT+8, 2025-1-7 21:19 , Processed in 1.266264 second(s), Total 78, Slave 62 queries .
