海全,
我想知道,如何将用户数据(如.bin或.hex文件)存储在闪存中以及如何从闪存中访问相同的数据,将其提供给用Verilog编写的程序的某个模块? 我是新来的,请让我知道 谢谢 以上来自于谷歌翻译 以下为原文 Hai all, i want to know , how can i store the user data like .bin or .hex file in flash memory and how to the access the same data from flash give it to some module of which program written in Verilog ?? i am new to all this kindly let me know thanks |
3个回答
您能否向我们提供有关您正在使用的威廉希尔官方网站
板的更多信息?
除了比特流PROM之外,它实际上是否有闪存,或者您是否计划在该PROM中使用备用空间? 哪些接口很容易获得? 以上来自于谷歌翻译 以下为原文 Can you give us more information about the board you're using? Does it actually have flash in addition to the bitstream PROM, or were you planning to use spare space in that PROM? What interfaces are easily available? |
ThanksVoyager的回复
我正在使用斯巴达3A入门套件,请找到用户指南的链接 https://www.xilinx.com/support/documentation/boards_and_kits/ug334.pdf 它有并行或闪存PROM和SPI串行闪存, 以上来自于谷歌翻译 以下为原文 Thanks Voyager for the reply i am using spartan 3A starter kit, please find the link of user guide https://www.xilinx.com/support/documentation/boards_and_kits/ug334.pdf it has parallel nor flash PROM and SPI serial flash, |
实际上我们正在试图在spartan 3a FPGA上使用moxie处理器,我们有该文件的.bin文件可执行文件,我们试图将这个.bin存储在闪存中并从闪存中取出数据(数据存在于.bin文件中)
这就像指令存储器一样,并将其提供给处理器。 我们不知道fpga上处理器上移植操作系统的确切过程,你能帮帮我吗? 我们做得对吗? 以上来自于谷歌翻译 以下为原文 actually we are trying to os on moxie processor on spartan 3a FPGA, we have .bin file executable of that os, we are trying to store this .bin in the flash memory and take data from flash memory (data present in .bin file) which acts like instruction memory here and give it to the processor. we don't know the exact process of porting OS on processor on fpga , can you help me out ? are we doing correctly? |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1787浏览 1评论
623浏览 1评论
485浏览 1评论
2036浏览 0评论
762浏览 0评论
GMT+8, 2025-1-13 21:10 , Processed in 1.548898 second(s), Total 81, Slave 65 queries .
