你好,
我们在可穿戴设备中使用LSM303AGR电子罗盘,我正在尝试获得倾斜补偿航向。我按照ST DT0058文件(计算倾斜测量和倾斜补偿电子罗盘),但我得到的标题不是倾斜(或俯仰)补偿。 我现在购买了带有X-NUCLEO-IKS01A2扩展板的NUCLEO-L476RG开发板,以使用Unicleo GUI Windows应用程序评估电子罗盘。我已经构建并下载了所需的固件到开发板,GUI正在发挥作用。我可以通过单击“用户消息”选项卡查看实时传感器数据,并且可以使用“数据记录”按钮将数据记录到文件中,但是如果单击“ECompass”按钮,则会显示ECompass窗口的框架,但是指南针没有。如果我点击Motion MEMS,Environmental或Scatter按钮,就会发生同样的事情。 我正在Windows 7上运行GUI的1.3.18.5002版,其中包含STM32 Nucleo板上的E-Compass固件(V1.0.0库)的V2.0.0。 这是一些截图。 以上来自于谷歌翻译 以下为原文 Hello, We are using the LSM303AGR e-Compass in a wearable device and I am trying to obtain a tilt compensated heading. I followed the ST DT0058 document (Computing tilt measurement and tilt-compensated e-compass), but the heading I get is not tilt (or pitch) compensated. I have now purchased a NUCLEO-L476RG development board with X-NUCLEO-IKS01A2 expansion board to evaluate the e-Compass using the Unicleo GUI Windows app. I have built and downloaded the required firmware to the development board and the GUI is working to a point. I can view the realtime sensor data by clicking on the User Messages tab, and I can log the data to file using the Datalog button, but if I click on the ECompass button then the frame of the ECompass window displays, but the graphic of the compass does not. The same sort of thing happens if I click on the Motion MEMS, Environmental or Scatter buttons. I am running version 1.3.18.5002 of the GUI on Windows 7 with V2.0.0 of the E-Compass firmware (V1.0.0 library) on the STM32 Nucleo board. Here are some screenshots. |
2785 浏览 1 评论
3252 浏览 1 评论
1827 浏览 1 评论
3672 浏览 6 评论
6068 浏览 21 评论
1350浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
374浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
470浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
294浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
218浏览 2评论
GMT+8, 2025-1-13 21:22 , Processed in 0.919713 second(s), Total 43, Slave 37 queries .
