我正在为我的大学工作,使用PIC32 MZ2048 EFH144(12位ADC),我将使用和声配置器版本2.02建立ADC/DMA:通过ADC接口10个模拟麦克风。PIC32 MZ具有6个ADC模块,(ADC0 ADC4)和ADC7。(ADC0 ADC4)一次多路复用两个信道;而ADC7通过ADC5-ADC42进行扫描/多路复用。对于12位ADC,这些信道的采样率是3.125毫秒。我想知道什么是关注点和差异,如果我用ADC0 ADC4接口所有10个麦克风(因为它们可以同时复用两个信道)。或者,使用模块ADC7和扫描/多路复用所有10个麦克风只使用这个ADC模块,从ADC5-ADC42扫描?另外,在这两种情况下,如果两个麦克风被复用到ADC0、ADC1等中,我如何区分数据。或者它们都被连接到ADC7中?我附上了一张ADC模块的图片,谢谢。
以上来自于百度翻译
以下为原文
I am working for a project for my University, using the PIC32MZ2048EFH144 (12 Bit ADC) and I will be set
ting up the ADC/DMA using h
ARMony configurator version 2.02.
Objective: Interface 10 analog microphones through the ADC.
This PIC32MZ has 6 ADC modules, (ADC0-ADC4) and ADC7. (ADC0-ADC4) multiplexes two channels at once; whereas, ADC7 scans/multiplexes through ADC5-ADC42. The sampling rate of these channels is 3.125 Msps for a 12-bit ADC.
I want to know what are the concerns and differences are if I am interfacing all 10 microphones with ADC0-ADC4 (Since these can multiplex two channels at once). OR, using module ADC7 and scanning/multiplexing all 10 microphones using just this ADC module, which scans from ADC5-ADC42?
Also, given either of these two circumstances, how do I differentiate between the data if two microphones are being multiplexed into ADC0, ADC1, etc.. or all of them being interfaced into ADC7?
I included a picture that refers to the ADC modules.
Thank You.
Attached Image(s)
