谢谢你的回答。
我已经尽力根据您的指令解决这个问题,包括修改“BL51定位”设置,并通过将我的功能添加到一个示例性固件中,从“CyPress USB CY3684EZ EZ-UBSFX2LPYDVK 1固件”编译我的项目。但问题仍然存在。
附件是我的固件,它是在UVIEW 4开发的,通过将两个文件“LCDCONMANCE.C”和“52驱动程序C”添加到示例固件“BulkRooT”中。如果我们只减少代码的大小,例如,在“LCDYCMDWORD(UCHAR CMD)”中删除“EZUBSJORD(5)”,Itcan就不会被编译。
我真的需要这些代码,并希望丰富控制器的功能。你能告诉我怎么编译吗?
当做。
袁刚
BulkLoop2.Zip
128.4 K
以上来自于百度翻译
以下为原文
Thank Anand and sai krishna for your reply.
I've try my best to solve the problem according to your instructions, including modifying the "BL51 Locate" settings and compiling my project through add my functions to a example firmware from "CypressUSBCY3684_EZ-USB_FX2LP_DVK1.0Firmware". But the problem is still there.
Attached is my firmware which is developed under uVision 4 through adding two files "LCDConMain.c" and "52-Driver.c" to the example firmware "bulkloop". It can not be complied if only we reduce the size of the code, for example, deleting "EZUSB_Delay(5);" in the function " LCD_CmdWrite(uchar cmd)".
I really need these codes and hope to enrich the function of the controller. Can you tell me how to compile it?
Regards.
Gang Yuan
谢谢你的回答。
当做。
袁刚
BulkLoop2.Zip
128.4 K
以上来自于百度翻译
以下为原文
Regards.
Gang Yuan
