是否可以在同一SPI总线上使用多个L6470电机驱动器IC - 常见的SDI,SDO,CK线路,但每个L6470都有独立的芯片选择信号?
当连接多个芯片时,我的实验板没有显示SDO上的任何数据。
我认为只要该芯片上的芯片选择不活动,SDO端口就是高阻抗?
#L6470
以上来自于谷歌翻译
以下为原文
Is it possible to use mul
tiple L6470 motor driver ICs on the same SPI bus - common SDI, SDO, CK line, but separate chipselect signals for each L6470?
My experimental board doesn't show any data on SDO when more than one chip is connected.
I thought that SDO ports are high impedance as long as chipselect at that chip is not active?
#l6470
