是德科技
张大妍
7年用户 192经验值
如何在win7操作系统中安装i3070
大家好我想在win 7 64位操作系统中安装i3070 7.20p,我只需在win7中安装虚拟PC和Windows XP模式,然后安装i3070 7.20p,安装时会显示“安装NutcRACKKER操作环境时出错”,
然后单击OK,它显示“20000006 OE安装程序进程未将成功返回到nutinsInstallOe”。
当点击OK,它继续安装直到完成,一切看起来都很好就像成功,但是当运行BT-basic或其他程序时,它显示缺少执行文件,当打开板的文件夹时,它是空的。
没有X Vision显示在右下角。
谁能告诉我如何解决这个问题,我只是将它安装到开发软件中。
我怀疑64位是不是适合安装它,所以我使用32位win7操作系统来安装它,与win7 64位相同的动作,同样的结果,都失败了。
谢谢肯
以上来自于谷歌翻译
     以下为原文
  hi all
i  want to install i3070 7.20p in win 7 64-bit operating system, i just install a Virtual PC and Windows XP mode in win7 , then install i3070 7.20p,it shows ''Error Installing NutcRACKKER Operating Enviroment' when install,then click OK, it shows "20000006 The OE installer process did not return success to nutinsInstallOe". and when click OK, it continue installing till completed, everything looks ok just like successful, but when run BT-basic or other program, it shows missing the execute file, when open the folder of boards, it is empty. and no X Vision shows in the right bottom corner. who can tell me how to fix this problem, i just intall it to develop software. i doubt the 64-bit can not be suitable to install it ,so i use a 32-bit win7 operating system to install it, the same action as win7 64-bit, the same result, both failed.
thanks
ken
回帖(2)
戚银燕
2019-5-9 16:03:38
嗨Ken,唯一适用于Windows 7进行测试开发的软件版本是从版本08.21或08.30开始08.30支持64位
以上来自于谷歌翻译
     以下为原文
  Hi Ken, the only software revisions that work for windows 7 for test development are from revision 08.21 or 08.30 onwards
08.30 supports 64 bit
张大妍
2019-5-9 16:18:51
以上来自于谷歌翻译
嗨oconnellj非常感谢你的回复,你能不能告诉我如何获得安装软件,因为我只是用笔记本电脑开发软件?
以上来自于谷歌翻译
     以下为原文
  hi oconnellj
thanks a lot for you reply, can you kindly tell me how to get the install software, since i just develop sofiware with laptop ?
