Cypress技术william hill官网
王婷
7年用户 228经验值
电荷泵供应多少电流?
我尝试使用电荷泵,可以在纸上(AN60580)
但是没有电流的规格。
所以我问你,水泵的供应量是多少?
SiO电流是25Ma,因此25Ma是最大电流。
是真的吗?
如果你知道,如何增加最大电流,请回答。
谢谢您。
以上来自于百度翻译
     以下为原文
  I try to use Charge Pump that can get in the Paper(AN60580)
    but there is no spec of current.
    so i ask to you, How much current does Charge Pump supply?
    SIO sink current is 25mA, therefore maybe 25mA is maximum current.
    is it true?
    And if you know, how increse maximum current, please reply.
    Thank you.
回帖(4)
郭雨桐
2019-5-10 10:00:57
你好!这是个有趣的问题。一般来说,电荷泵用于设置参考电压或用作电平移位器,它们不用于驱动负载,因此电荷泵不被用作电流驱动器。当你不断地从负载电容中汲取电流时,电源(在我们的情况下,SIO)应该能够将电容器充电回到你需要的电压。由于电流源(实际的SiO引脚)现在只提供了一半的时间,所以可以近似在SIO上建立的电荷泵的容量大约为12Ma。事实上,它甚至小于12Ma。
不要烦恼!!!!如果需要额外的电流,可以在连接器中连接更多的引脚。
以上来自于百度翻译
     以下为原文
  Hello there ! Thats an interesting question. Generally chargepumps are used to set reference voltages or used as level shifters and they are not used drive loads and hence it is not use case of charge pump to be used as current drive. As you keep drawing current from the load capacitor, the source(in our case SIO) should be capable of charging the capacitor back to maintian your required voltage. You could approximate the current capability of the charge pump built on the SIO to be about 12mA, since the current source(actual SIO pin)  is now available for only half the time. Actually its even lesser than 12mA.
    Fret not !!! If you need additional current, you can connect more number of Pins in paralle.
王婷
2019-5-10 10:16:16
谢谢你的回复。
这对我很有帮助。
再次谢谢你。
以上来自于百度翻译
     以下为原文
  Thank you for your reply.
    It is very helpful to me.
    Thank you again.
李玉林
2019-5-10 10:26:17
好问题,
谢谢你的答案U2。甚至我也对同样的事情感到好奇。
以上来自于百度翻译
     以下为原文
  Good question,
    and thanks for the answer U2.. Even I was curious about the same..
罗敏
2019-5-10 10:42:43
谢谢U2的回答,
我知道这是12MAX MAX,通常用作电压基准。
以上来自于百度翻译
     以下为原文
  thanks for the answer from  U2,
    i know that  is 12ma  max  and generally  it  used as voltage reference
