你好,西奎师那!谢谢你的回复。
当我试图传输一个短的数据包时,我可以正确地得到它,但是我发现了一个额外的00 00×00包,但是我只是在FX3中设置了一个缓冲区!
另一个问题是,我为每个DMA通道只设置一个缓冲器,然后当短包写入FX3时,标志不显示满,标志显示什么?短包不让标志显示缓冲区满了吗?
当做,
绒布
以上来自于百度翻译
以下为原文
hello,
sai krishna! thanks for your reply.
when i try to transfer one short packet, i can get it in a packet correctly but i found a extra 00 00 00 00 packet, but i just set one buffer in the FX3 !
another problem is that i set only one buffer for each dma channel , then when the short packet is write into the FX3, the FLAG does not show full , what does FLAG show? short packet doesn't make the FLAG show the buffer is full?
regards,
lint
你好,西奎师那!谢谢你的回复。
当做,
绒布
以上来自于百度翻译
以下为原文
hello,
regards,
lint
