我也有同样的问题。我试图在INEMO-M1模块和Raspberry Pi之间进行通信,我已经尝试了所有可能性(电源选项,启用选项,通信协议,如I2C,SPI,USART,USB等),但我每次尝试都失败了。虽然我没有评估板,但我下载了评估板的软件,并尝试将模块连接到PC,但无法识别设备。此外,还缺少文档以及如何使用此模块。我甚至无法理解模块是否正常工作。可能是我在焊接它时烧了模块,我不确定但应该有办法检查模块。任何帮助将不胜感激。谢谢。
以上来自于谷歌翻译
以下为原文
I have the same problem. I am trying to get communication between INEMO-M1 module and Raspberry Pi, I have tried all the possibilities (power supply options, enable options, communication protocols like I2C, SPI, USART, USB etc.) but I have failed each try. Although I don't have the eval board I downloaded the software of the eval board and tried to connect the module to the PC but the device is not recognized. Also there is lack of documentation and how to use this module. I could not even understand whether the module works properly or not. May be I have burned the module while soldering it, I am not sure but there should be a way to check the module. Any help will be appreciated. Thank you.
以上来自于谷歌翻译
以下为原文
