大家好,我使用MPLAB X IDE 3.10和XC32编译器和pic32mx256f064h。第二天,如果我打开板,它就不工作了。在编程板之后,它工作得很好。我怀疑我的代码有错误。如果是的话,我会把我的代码。你能解决这个问题吗?
以上来自于百度翻译 以下为原文 hi all, i using MPLAB X IDE 3.10 and XC32 compiler and pic32mx256f064h. after programming my pic with pickit3 , it works well. The next day if i turn ON the board, it doesnt works. after programming the board it works well. i suspect there is error in my code.if it is i ll put my code. would you clear this problem.? |
3个回答
复位引脚是否启用和浮动?有没有配置为数字输入的引脚可以浮到非逻辑电平?PICTIT3控制复位线,使目标在连接时可以工作。
以上来自于百度翻译 以下为原文 Is the RESET pin enabled and floating? Are there any pins configured as digital input that may float to a non-logic level? The PICkit3 controls the RESET line so the target may work when it is connected. |
你也可以知道,PIC是用调试构建来编程的,所以它只能和从IDE附加并启动的PK3一起工作。在调试运行中可以禁用。4-由于PK3的存在而被拉高或拉低的浮动引脚。排除:a-程序丢失/改变,PIC闪存恢复时间略高于24小时。……THA是什么意思?你想让别人帮你做吗?如果你愿意付多少钱?格林先生:开玩笑吧。
以上来自于百度翻译 以下为原文 Hi Can be also that the PIC is being programmed with a debug build so it only works with the PK3 attached and started from the IDE. Things to check: 1 - Type of build 2 - Power supply and decoupling of the PIC, might be experiencing a bad POR. 3 - Pins with analog functions that are not disabled in code, could be disabled on a debug run. 4 - Floating pins that are pulled high or low by the presence of the PK3. Things to exclude: a - Loss/changes in program, the PIC flash retension time is a bit more than 24 hours. b - PICs that self program or erase themselves withoutv power. c - Pranormal phenomena d - ............... What does tha mean. Do you want someone to do your work for you? mad: If so how much would you pay? mr green: Just kidding.... Best regards Jorge |
谢谢你的建议。我喜欢你开玩笑的评论,jorge F.mad:我的代码实际上不是指我自己的东西。我只是说“my code”的意思是有任何特殊的配置用于这个目的。是的,它工作,感谢PS.Paul和Jorge F。
以上来自于百度翻译 以下为原文 hi thanks for your suggestion. i like your kidding comment jorge F.mad: my code means actually not my own stuffs.i just say 'my code' means is there any special configurations are there for this purpose. yes it works, thanks PStech Paul and Jorge F. |
5288 浏览 9 评论
2059 浏览 8 评论
1969 浏览 10 评论
3233 浏览 3 评论
2277 浏览 5 评论
824浏览 1评论
710浏览 1评论
654浏览 1评论
710浏览 0评论
608浏览 0评论
GMT+8, 2025-1-13 16:14 , Processed in 1.129549 second(s), Total 79, Slave 63 queries .
