PIC12LF1552使用两个输出保护环。我的PCB就是这样安排的。MPLAB代码配置器只允许我打开引脚管理器网格中Tx保护线上的一个引脚。我如何告诉它我需要使用两个引脚保护A和保护B,如所有PIC12LF1552文档中所述。我使用两个按钮(没有PROX传感器)。保护环对两个按钮都是通用的。MCC版本:3.26.2MPLABX版本:3.50操作系统和版本:Windows 10 Pro(64位)编译器版本:XC8(v1.40)设备名称:PIC12LF1552Aswilliam hill官网
指南建议,附加IDE日志和MCC配置文件(重命名为.txt)。
MutCHCODECONFIG.TXT(113.29 KB)-下载132次 以上来自于百度翻译 以下为原文 The PIC12LF1552 uses two outputs for the Guard Ring. That's the way my PCB is laid out. The MPLAB Code Configurator only lets me turn on ONE pin on the Tx Guard line in the Pin Manager Grid. How do I tell it I need to use both pins Guard A and Guard B, as described in all the PIC12LF1552 documentation. I am using two buttons (no Prox sensors). The guard ring is common to both buttons. MCC version: 3.26.2 MPLAB X version: 3.50 Operating System and version: Windows 10 Pro (64-bit) Compiler version: XC8 (v1.40) Device name: PIC12LF1552 As Forum guidelines suggest, attaching IDE Log and MCC Configuration file (renamed to .txt). Attachment(s) MPLAB_IDE-Log.txt (104.01 KB) - downloaded 130 times mTouchCodeConfig.txt (113.29 KB) - downloaded 132 times |
嗨,Jpax,你可以将你的板上的ADGRDA输出配置为TX/Guald.当前MCC只支持数据表中所述的电阻分压器保护。基于实验,单ADGDRAW输出同时执行双输出(ADGRDA和ADRDB),并且节省了两个外部的成本。PIC上的电阻和一个引脚。
以上来自于百度翻译 以下为原文 Hi Jpax, You can configure the ADGRDA output on your board as the Tx/guard. The current MCC only doesn't support resistor divider guard as stated in the datasheet. Based on experiments, the single ADGDRA output performs as well as the dual output(ADGRDA and ADRDB), and it saves the cost of two external resistors and one pin on the PIC. |
5289 浏览 9 评论
2059 浏览 8 评论
1969 浏览 10 评论
3233 浏览 3 评论
2277 浏览 5 评论
824浏览 1评论
710浏览 1评论
654浏览 1评论
710浏览 0评论
609浏览 0评论
GMT+8, 2025-1-14 06:45 , Processed in 1.053668 second(s), Total 77, Slave 61 queries .
