感谢回复将ctrl lan编码与N1912A一起作为初始局域网链接道歉,如果这是一个愚蠢的问题,因为我刚刚开始编写代码并且我的经验是有限的。如果你有任何例子,我可以通过u***链接
无论是哪个都很棒还是指向我需要哪些指南开关,如果我去u***路线我还需要除标准电缆以外的任何东西将电脑连接到N1912A.again感谢您的帮助
以上来自于谷歌翻译
以下为原文
Thanks for reply would the ctrl lan coding work with the N1912A as an initial lan link apologies if this is a dumb question as i'm just getting into writing code and my experience is limited.
Or could i link via u*** if you have any examples for either that would be great or point me to which guides i need to be swotting up on, also if i go the u*** route would i need anything other than a standard cable to join the pc to the N1912A.
again thanks for your help
以上来自于谷歌翻译
以下为原文
