Microchip
王金凤
7年用户 221经验值
怎么绘制图形LCD的高效线
你好,我正忙于图形LCD显示器,我使用的是PIC16F1789和12864b的液晶显示器,在并行模式下。有人知道什么是最有效的画线方法吗?IDENT WANDTO使用除法,不需要更多像素,那么需要,也许有人给我一些建议?我想我不会得到1分左右,所以我张贴。谢谢提前,圣诞快乐!
以上来自于百度翻译
      以下为原文
    Hi, i am busy with a graphical LCD display, i am using a PIC16F1789 and a 12864b LCD in parallel mode.
Does anyone know what is the most efficient way to draw a line ?,
I dont wanto use divide, and dont wanto paint more pixels then is needed,
maybe someone has some advice for me ?
I think i dont get around 1 divide, so i am posting here.
thanks in advance, Merry Christmas
回帖(6)
冯待策
2019-5-28 14:15:10
谢谢,很多阅读,有一个很好的用餐者。
以上来自于百度翻译
      以下为原文
    Thanks, alot to read, have a nice diner.
陈晨
2019-5-28 14:25:51
再次投票给Bresenham。它被认为是最有效的方法,用任意的角度画直线,使用互联网数学。
以上来自于百度翻译
      以下为原文
    Another vote for Bresenham.
It is noted as the most efficient way to draw a straight line , at any angle,using internet math
王焕树
2019-5-28 14:42:43
当然,如果你事先知道直线是垂直的、水平的还是倾斜的,就比较容易了。
以上来自于百度翻译
      以下为原文
    Of course, it's easier if you know beforehandhand if the line is vertical, horizontal, or sloped.
Was not mentioned in the first post.
张娜
2019-5-28 14:56:58
是的,我想补充一点:实际上,我认为(希望)Bresenham的链接会考虑到这一点……但是,最终,对于低端CPU来说,这一点更重要。
以上来自于百度翻译
      以下为原文
Yeah, I wanted to add about that: I actually think (hope) that links for Bresenham take that into account...
Though, in the end, it's more important for low-end CPUs, I'd say.
