根据原始问题,是否可以进行连续无间隙测量。
SAMPLE:COUNT允许最多1,000,000个点,但是因为在使用R获取期间可以读取读数吗?
应该可以避免内存溢出,从而允许任意数量的点?
菲尔
以上来自于谷歌翻译
以下为原文
Is it possible to have continuous gap-free measurement, as per the original question. The SAMPLE:COUNT allow a maximum of 1,000,000 points, but since the readings can be read during acquisition using R? it should be possible to avoid memory overflow and thus allow an arbitrary number of points?
Phil
菲尔
以上来自于谷歌翻译
以下为原文
Phil
