我同意数据表令人困惑,但不要担心。为了您的信息,一些设备的底部靠近引脚1有“引脚1指示灯”。我可能是小点或三角形,看起来像非常小的焊盘。句子说你不应该焊接这个指标。当然需要连接引脚1。
似乎不是LIS2DH12的情况,因为切角指示了一个。
以上来自于谷歌翻译
以下为原文
I agree the datasheet is confusing, but don't worry. For your information some devices have 'pin 1 indicator' on the bottom close to pin 1. I could be small dot or triangle, which looks like very small pad. The sentence says you should not solder this indicator. The pin 1 of course needs to be connected.
It seem it is not the case of LIS2DH12, beacuse pin one is indicated by cut corner.
以上来自于谷歌翻译
以下为原文
