您好,我一直在考虑为我的顶点设计项目使用SPARTAN 3AN入门套件,我唯一与此套件相关的问题是它似乎只有一个输入到每个ADC(VINA和VINB)。
我需要4个ADC输入。 我可以通过多路复用2为每个模数转换器复用我的4个输入吗? 如果是这样,我该怎么做呢? 以上来自于谷歌翻译 以下为原文 Hello, I've been thinking about using the SPARTAN 3AN Starter Kit for my capstone design project, the only problem I have associated with this kit is that it seems to only have one input into each the ADC (VINA and VINB). I need 4 inputs into the ADC. Is it possible for me to multiplex my 4 inputs by multiplexing 2 for each Analog to digital converter? If so, how can i go about doing that? |
请不要在多个主题和多个william hill官网
中交叉发布相同的主题。
这使得有兴趣关注(或参与)讨论的穷人变得混乱。 请在您的其他主题中继续讨论,这个主题在Boards and Kitswilliam hill官网 中更合适。 谢谢。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索william hill官网 (并搜索网页)以寻找类似的主题。 不要在多个william hill官网 上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付william hill官网 帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Please do not cross-post the same topic in multiple threads and multiple forums. This muddles up the poor users who are interested in following (or participating in) the discussion. Please continue this discussion in your other thread, this topic is more appropriate in the Boards and Kits Forum. Thank you. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
2463 浏览 7 评论
2854 浏览 4 评论
2315 浏览 9 评论
3399 浏览 0 评论
2496 浏览 15 评论
2029浏览 1评论
639浏览 1评论
496浏览 1评论
2045浏览 0评论
774浏览 0评论
GMT+8, 2025-1-27 14:48 , Processed in 1.269719 second(s), Total 76, Slave 60 queries .
