ST意法半导体
周菊
7年用户 186经验值
使用霍尔传感器的传感X-CUBE-SPN8电机控制示例?
我在这个william hill官网 中发现只有更多相同的请求,没有答案。今天最常用的霍尔传感器用于电机控制。 X-CUBE-SPN8中提供的6步BLDC代码示例仅为无传感器。 X-CUBE-SPN8包中的驱动程序文件专门用于霍尔传感控制(STM32f4xx_hal_tim_ex.c和stm32f4xx_hal_tim_ex.h),但未找到使用示例。请有人指出任何一个例子。我将继续发布这个,直到有人知道会回复。
提前致谢。
#sensor#motor-control #sensored#x-cube-spn8#x-nucleo-ihm08m1 #hall #bldc
以上来自于谷歌翻译
以下为原文
I found only more requests of the same in this forum and no answers. Using Hall sensors for motor control  most typical today. 6-step BLDC code example provided in X-CUBE-SPN8 is sensorless only. There are driver files in X-CUBE-SPN8 package specifically made for Hall sensored control (stm32f4xx_hal_tim_ex.c and stm32f4xx_hal_tim_ex.h) but no examples of usage found.  Please somebody point to any example. I will keep posting this until somebody who knows will reply.
Thanks in advance.
#sensor #motor-control #sensored #x-cube-spn8 #x-nucleo-ihm08m1 #hall #bldc
回帖(19)
周菊
2019-6-10 11:40:06
我不得不提到制造X-CUBE-SPN8的X-NUCLEO-IHM08M1扩展板确实有霍尔传感器的连接器。所以一切都是为霍尔感应控制设计的,但没有代码示例。
我知道购买此板的许多用户(如果不是绝大多数)将使用霍尔传感器,请帮助所有这些。
以上来自于谷歌翻译
以下为原文
I had to mention that the X-NUCLEO-IHM08M1 expansion board for which  X-CUBE-SPN8 was made, does have connectors for Hall sensors. So everything was designed ready for Hall sensored control but no examples of code.
I know that many users (if not vast majority) who buy this board will be using Hall sensors, please help all of those.
周菊
2019-6-10 11:59:23
有没有人使用STM32进行感应BLDC电机控制?世界上有人使用X-CUBE-SPN8进行霍尔感应电机控制吗?我是这个基本应用程序的第一个用户吗?
以上来自于谷歌翻译
以下为原文
Is there anybody who used STM32 for sensored BLDC motor control? Anybody in the world used X-CUBE-SPN8 for Hall sensored motor control?   Am I the first user of it for such basic application ?
符伯峪
2019-6-10 12:23:02
好的,但是没有人点击过“我也有这个问题”。
建议您联系当地的ST办公室并与FAE联系
以上来自于谷歌翻译
以下为原文
Ok, but nobody has clicked 'I also have this question' on yours.
Suggest you contact your local ST office and connect with an FAE
李郝荫
2019-6-10 12:58:23
我问过了
Poli.Enrico
to来看看。
 注意:原始帖子包含大量线程对话,只能迁移到第9级
以上来自于谷歌翻译
以下为原文
I have asked
Poli.Enrico
‌ to have a look.
Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level
