我怀疑整个CCPTMRS寄存器是来自另一个数据表的复制和粘贴错误。在数据表中的任何地方,似乎都没有提到将TMR0与CCP一起使用的能力,它只是说TMR1。这将是一个相当重要的特性,因为需要对16个信号进行多路复用以在它们之间切换。计时器。我建议用Microchip寄一张支持票来澄清这一点。编辑:我刚才发现这在“28.1捕获模式”的文本中提到了,即使它没有显示在紧接下面的框图中。绝对值得举起一张支持票。
以上来自于百度翻译
以下为原文
I suspect that whole CCPTMRS register is a copy & paste error from another datasheet.
The ability to use TMR0 with the CCP doesn't appear to be mentioned anywhere else in the datasheet, it just says TMR1.
This would be a fairly major feature, as 16 signals need to be multiplexed to switch between timers.
I would suggest lodging a support ticket with Microchip to clarify this.
Edit: I just spotted that this is mentioned in the text under "28.1 Capture Mode", even though it's not show on the block diagram immediately below this.
Definitely worth raising a support ticket.
以上来自于百度翻译
以下为原文
