谢谢你的回答。
是的,我使用了控制中心和UBFS组件,并能够发送更多的1字节和接收。当我把这个类变成HID时,我已经无法使用控制中心,因为发送的数据不活跃。我需要配置PSoC 3作为一个HID设备。我使用LIUBSB,因为它允许在不同的操作系统中使用。
以上来自于百度翻译
以下为原文
Thank you for your answer.
Yes I did it using Control Center and USBFS component and was able to send more then 1 byte and recieve. When I changed the class into HID I was already unable to use Control center, because data to sent wasn't active. I need configure PSoC 3 as a HID device. I'm using Libu***, because it's allowed to be used in different operating systems.
谢谢你的回答。
以上来自于百度翻译
以下为原文
