我是一名软件工程师,但我作为业余爱好者一直在与各种
开发板合作。我的最新购买是eBay上的最低STM8板(
http://r.ebay.com/YaYe2P
所以我可以开始学习那个平台了。
它配有一个微型USB端口。但是,我看到的帖子显示你需要一个单独的程序员(ST-Link)来编程(SWIM)。我很欣赏你如何在Windows上启动和运行其中一个编程。
我的系统上有COSMOS和STVP设置。还有什么需要吗?
2.我是否需要使用ST-Link或其他编程器,还是可以使用USB-to-TTL设备通过USB完成?
3.如果必须有一个单独的程序员,最好的选择是什么?
感谢您的帮助!
#stm8s103f3p6编程
以上来自于谷歌翻译
以下为原文
I am a software engineer, but I have been working with various development boards as a hobbyist. My latest purchase was a minimum STM8 board off ebay (
) so I could start learning that platform.
It comes with a micro USB port. However, the posts I'm seeing show you need a separate programmer (ST-Link) to program it (SWIM). I'd appreciate some insight on how you get up and running programming one of these on Windows.
1. I've got COSMOS and STVP setup on my system. Anything else needed?
2. Do I need to have an ST-Link or other programmer or can it be done over USB with a USB-to-TTL device?
3. If it must have a separate programmer, what is the best choice?
Thank you for your help!
#stm8s103f3p6-programming
