你好,
我们检查了从您所附的CalthWistar表,发现配置输出的PPM错误非常高。这可能是错误的输出频率的原因。你能提供你的要求(输入频率和要求的输出频率)还是附加时钟精灵项目?然后,我们可以为您的应用程序创建一个新项目。
谢谢和问候,
苏德什
以上来自于百度翻译
以下为原文
Hi,
We checked the table from ClockWizard you attached and found that the PPM error for the configured outputs are very high. This can be the reason for wrong output frequencies. Can you provide your requirement (Input frequency and required output frequencies) or, attach your clock wizard project? Then we can create a new project for your application.
Thanks and Regards,
Sudheesh
你好,
谢谢和问候,
苏德什
以上来自于百度翻译
以下为原文
Hi,
Thanks and Regards,
Sudheesh
