赛灵思
刘婷婷
7年用户 219经验值
DNA读出Digilent Atlys与Spartan 6高度倾斜
您好我在之前的项目中使用了Virtex 6并使用了我以100 MHz运行的DNA端口。现在我尝试在Digilent Atlys Board上使用与Spartan 6-45相同的模块,并且我得到500 ns的极端偏差
然后我开始阅读勘误并得到一点困惑,因为ist说它在某些设备上不支持。有人知道它是否与Atlys主板上的斯巴达6 FPGA完全一样......?
以上来自于谷歌翻译
以下为原文
Hello i used the Virtex 6 in a previous Project and used the DNA Port which i ran at 100 MHz.
Now i tried to use the same module with the Spartan 6-45 on the Digilent Atlys Board and i got an extreme skew of 500 ns.
Then i started reading the errata and got a Little confused as ist says that it is Not supported on some devices.
Does anyone know if it is definatly the same with the spartan 6 FPGAs on the Atlys boards...?
回帖(5)
潘晶燕
2019-7-5 15:13:19
EN113,115,117,118
哪个勘误有问题?
每个都有受影响的零件表。
您必须检查零件的标记以查看它是否在列表中。
Austin Lesea主要工程师Xilinx San Jose
以上来自于谷歌翻译
以下为原文
EN113, 115, 117, 118
Which errata is in question?  Each has a table of parts affected.  You would have to examine the markings of the part to see if it is on the list.
Austin Lesea
Principal Engineer
Xilinx San Jose
鄢蓉
2019-7-5 15:26:05
EN 117我猜。
Atlys FPGA是:采用324引脚BGA封装的XilinxSpartan®-6 LX45 FPGA。
那么问题是它是否类似于XC6SLX45-2CSG324CES JTAG ID 1?
以上来自于谷歌翻译
以下为原文
EN 117 i guess.
And the Atlys FPGA is: Xilinx Spartan®-6 LX45 FPGA in a 324-pin BGA package.
So the question is if it is similar to the XC6SLX45-2CSG324CES JTAG ID 1?
潘晶燕
2019-7-5 15:43:01
G,
听起来很合适(封装,引脚数量不重要,它是CES名称和JTAG ID号)。
以上来自于谷歌翻译
以下为原文
g,
Sounds like it applies (the package, number of pins is not important, it is the CES designation, and the JTAG ID number).
Austin Lesea
Principal Engineer
Xilinx San Jose
鄢蓉
2019-7-5 16:00:48
有用!
修订版4。
现在我需要用2 MHz读取它,由于输入为100 MHz,因此难以生成,因此我应该创建10 MHz并将其提供给第二个DCM以生成2 MHz?
以上来自于谷歌翻译
以下为原文
It works!
Its Revision 4.
Now i need to read it out with 2 MHz, which uld be hard to generate as the input is 100 MHz so should i create 10 MHz and give it to a second DCM to generate 2 MHz?
