嗨,当我们在FIFO或GPIF FIFO中讨论FIFO时,FIFO是终结点缓冲器吗?也就是说,如果使用奴隶FIFO,当外部CPU将一个字节写入从属FIFO时,CPU直接将字节写入端点缓冲器中,或者外部CPU只将字节写入FIFO,然后在EZ-USB中的一些逻辑从FIFO中取出字节,然后将其写入端P。OIN缓冲区?
谢谢! 以上来自于百度翻译 以下为原文 hi , when we talking about the fifo in the slave fifo or gpif fifo, is the fifo means the end point buffer ? that is ,if i use slave fifo , when the extern cpu writes one byte to the slave fifo , is it the cpu directly writes the byte into the end point buffer ,or the extern cpu just writes the byte into the fifo and then some logic in the ez-u*** get the byte out of the fifo and then write it to the end point buffer ? thanks! |
你好,
我相信你是指FX2LP。FIFO和端点缓冲器本质上是相同的物理缓冲区。当FIFO处于USB域的控制之下时,称为端点缓冲器,否则为从FIFO。 它取决于FX2LP被配置为工作的方式(自动/手动),是否写入到从FIFO的数据直接到EP缓冲器。在自动模式下,写入到从FIFO的数据被自动提交到USB域(控制被传送到USB域);即可以作为EP缓冲器访问。在手动模式下,必须显式提交。 我相信ApHTTP://www. CyPress。RID=12926。 当做, 加亚特里 以上来自于百度翻译 以下为原文 Hi, I believe you are referring in terms of FX2LP. FIFO and endpoint buffer is essentially the same physcal buffer. It is called as endpoint buffer when the FIFO is under the control of USB domain, else Slave FIFO. It depends on which mode FX2LP is configured to work (auto/ manual), whether the data written to Slave fifo goes to EP buffer directly or not. In Auto mode, the data written to Slave FIFO is automatically committed to USB domain(the control is transferred to USB domain); i.e. is accessible as EP buffers. In manual mode, it has to be explicitly committed. I believe it would be clear with the AN http://www.cypress.com/?rID=12926. Regards, Gayathri |
756个成员聚集在这个小组
加入小组2124 浏览 1 评论
1866 浏览 1 评论
3682 浏览 1 评论
1802 浏览 6 评论
1549 浏览 1 评论
613浏览 2评论
456浏览 2评论
451浏览 2评论
403浏览 2评论
1089浏览 2评论
GMT+8, 2025-1-14 04:33 , Processed in 0.443608 second(s), Total 42, Slave 36 queries .
