##### 100ask Bootloader for OpenJTAG #####
[n] Download u-boot to Nand Flash
[o] Download u-boot to Nor Flash
[k] Download Linux kernel uImage
[j] Download root_jffs2 image
[y] Download root_yaffs image
[d] Download to SDRAM & Run
[z] Download zImage into RAM
[g] Boot linux from RAM
[f] Format the Nand Flash
Set the boot parameters
Boot the system
[r] Reboot u-boot
[q] Quit from menu
Enter your selection: n
USB host is connected. Waiting a download.
Now, Downloading [ADDRESS:30000000h,TOTAL:198326]
RECEIVED FILE SIZE: 198326 (193KB/S, 1S)
NAND erase: incorrect device type in bootloader
'bootloader' is not a number
NAND write: incorrect device type in bootloader
我输入n 下载 u-boot 到nand flash 可以 却出现NAND write: incorrect device type in bootloader
'bootloader' is not a number 这个错误, 结果是 没有成果下载到nan ! 但是 我用 nand wrie 可以把二进制文件下载到 nand中去 , 我好久以前用n命令 也行 但是不知道 为什么这会 会出现这个错误
