各位大家好,我正在尝试使用我在Xilinxwilliam hill官网
下载的SP605连接套件参考设计,
我阅读了用户指南:我了解了如何通过BAR0和BAR1访问(读/写)寄存器,但我不明白如何通过PCIe(当然还有DMA)访问SP605 DDR。 我在哪里以及如何写入寄存器? 我的目标应该是使用TRD通过PCIe完全访问DDR3,包括读写......我怎么能这样做? 谢谢你的帮助! 以上来自于谷歌翻译 以下为原文 Hello everybody, I'm trying to use the SP605 connectivity kit reference design I downloaded in Xilinx forum, I read the User Guides: I understood how to access (read/write) to registers via BAR0 and BAR1, but I didn't understand how to access to SP605 DDR via PCIe (and DMA, of course). Where and how have I to write in registers? My goal should be to use the TRD to have a complete access to DDR3 by PCIe, both reading and writing... how could I do that? Thanks for your help! |
以下SP605板链接中的x1PCIe-DMA-DDR3支持参考设计可能对您有用
http://forums.xilinx.com/t5/Spartan-Family-FPGAs/Aurora-in-SIMPLEX-TX-RX/td-p/361555 _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他william hill官网 用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 The x1PCIe-DMA-DDR3 supporting reference designs in the below SP605 boards link may useful to you http://forums.xilinx.com/t5/Spartan-Family-FPGAs/Aurora-in-SIMPLEX-TX-RX/td-p/361555 ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1796浏览 1评论
624浏览 1评论
486浏览 1评论
2037浏览 0评论
763浏览 0评论
GMT+8, 2025-1-14 05:43 , Processed in 1.196562 second(s), Total 75, Slave 59 queries .
