我创建了一个新帖子,因为由于您网站的功能,我无法回复第一个帖子。
问题再次出现:
我用过
Viper06X(30KHz)作为降压获得9V输出
,没有负载我有正确的输出电压。但
当我连接任何负载(即使它很轻)时,输出电压下降
随着负载电阻的降低,输出电压降低!!
只有90mA负载就达到了7.8VDC!
#viper06x
以上来自于谷歌翻译
以下为原文
I have created a new post because I cannot reply on the first one due to func
tionality of your website.
The problem again :
I have used
Viper06X (30KHz) as a buck to get 9V output
, with no load I have the right output voltage. But
when I connect any load (even it is light) the output voltage drops
As the load resistance decreases the output voltage decreases !!
It reached 7.8VDC with only 90mA load !!
#viper06x
