嗨,
在我的设计中,我使用了MT46H32M16,512Mb LPDDR RAM,我可以将它连接到我的斯巴达设备,并运行128Mb的meory测试(由EDK提供)。 现在我想测试整个内存512Mb,但我不知道如何将128Mb的范围更改为512Mb。 通过更改端口P0更高的地址收到错误。 我是否需要添加多个端口并为其添加地址才能获得完整的512Mb寻址。 以上来自于谷歌翻译 以下为原文 Hi, In my design I have used MT46H32M16, 512Mb LPDDR RAM, I am able to interface it to my spartan device and run the meory test(provided by EDK) for 128Mb. Now I would like to test whole memory 512Mb , but I dont know how to change the range 128Mb to 512Mb. By changing Port P0 higher address am getting error. Do I need to add multiple ports and assighn the addres for it to get full 512Mb addressing. |
嗨,
我不确定从EDK明智但是检查你是否有处理器方面的限制,你只能访问128Mb 从MIG / MPMC明智地,您将在用户界面获得足够的地址位 无需多个端口,但寻址取决于您的端口宽度 请参阅以下链接了解详情 http://www.xilinx.com/support/answers/43360.html 问候, Vanitha。 -------------------------------------------------- -------------------------------------------请在发布前进行谷歌搜索, 您可能会找到相关信息。请留下帖子 - “接受为解决方案”,如果提供的信息有用且回复,请给予赞誉 以上来自于谷歌翻译 以下为原文 Hi, I am not sure from EDk wise but check if you have any limitation from processor wise that you can access only 128Mb from MIG/MPMC wise you will get enough address bits at the user interface No need to have multiple ports but addressing depends on your port widths Please see below link for details http://www.xilinx.com/support/answers/43360.html Regards, Vanitha. --------------------------------------------------------------------------------------------- Please do google search before posting, you may find relavant information. Mark the post - "Accept as solution" and give kudos if information provided is helpful and reply oriented |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1797浏览 1评论
624浏览 1评论
486浏览 1评论
2037浏览 0评论
763浏览 0评论
GMT+8, 2025-1-14 08:36 , Processed in 1.546718 second(s), Total 75, Slave 59 queries .
