Microchip
李艳婷
7年用户 246经验值
PIC16F1459的数据表中VoL大幅度降低该怎么办?
我查阅了PIC16F1459的数据表,发现IO引脚在IoL=8mA,VDD=5V时输出低电压VoL最大值=0.6V,我相信如果降低电流IoL,VoL会降低很多,一些接口芯片对逻辑输入低电压电平(ViL)有严格的限制,低到0.4V;如果能找到描述微芯片控制器的VoL、ViL、VoH、ViH过电流和温度等参数的详细曲线就更好了。
以上来自于百度翻译
      以下为原文
    I checked into the datasheet of PIC16F1459,only found that IO pin's output low voltage VoL maximun=0.6V at IoL=8mA,VDD=5V;
i believe that the VoL could be much lower if we reduce current IoL;
some interfacing chips have strict limit with logic input low voltage leve(ViL),which is low to 0.4V;
it would be better if somewhere we coud find the detailed curves describing parameters such as the VoL,ViL ,VoH,ViH over current and temperature for microchip controller.
回帖(3)
薄坤坤
2019-7-17 13:56:27
用MixChIPSUN制作支持票
以上来自于百度翻译
      以下为原文
    Create a support ticket with Microchip
Susan
李亦然
2019-7-17 14:15:25
或者至少如果启用了I2c硬件,则相应的引脚(SDA,SCL)在电流=3mA时输出低压<0.4V,这在I2c规范中提到。
以上来自于百度翻译
      以下为原文
    or at least if I2c hardware enabled,then corresponding pin(SDA,SCL) output low voltage <0.4V at current=3mA;which is mentioned in I2c spec.
王耀昱
2019-7-17 14:29:24
另一方面,你的一些接口芯片也有电压或电流容限,所以开发者必须查看Gelald-。
以上来自于百度翻译
      以下为原文
Of the other hand some of your interface chips have also voltage or current tolerances.
So the developer have to look for.
Gerald
